ZF6 Pilot Bearing for the 7.3 Power Stroke Diesel
For Sale
Miscellaneous
  • Miscellaneous - ZF6 Pilot Bearing for the 7.3 Power Stroke Diesel - New - All Years  All Models - Alvarado, TX 76009, United States
    Expired
    Expired
  • Price
    $135
  • Location Alvarado, TX, 76009, USA
  • Condition New
Description:
FS: Long term pilot bearing solution for the ZF6 & 7.3 Power Stroke diesel. This was a combined effort of a few FTE'rs dedicated to helping to keep these older trucks on the road.
The bearing is a two piece design that provides a steel sleeve to overcome years of wear or a damaged input shaft and a self-lubricating bronze bushing.
The input sleeve is CNC machined from 4140 prehardened steel and the bronze bushing is machined from 841 sintered oil impregnated bronze. The sleeve returns the friction surface of the input shaft to like new condition while the sintered bronze will channel lubricants between the bushing itself and the steel sleeve.
The bushing thickness has been upgraded in order to provide unmatched support between the flywheel and the input shaft.
Kit includes:
1x Sintered bronze bushing
1x Input shaft repair sleeve
1x Alignment sleeve
1x Loctite 609 single use capsule
Click here to purchase: https://www.builtbyahigherstandard.c...-pilot-bearing
Here are a few links on FTE that highlight pilot bearing issues and need for a long term solution:
https://www.ford-trucks.com/forums/1...l#post17489274
https://www.ford-trucks.com/forums/1...l#post20800628
https://www.ford-trucks.com/forums/1...l#post19713154
Old Jul 20, 2024 | 08:22 PM
Shadetree68's Avatar
Shadetree68
3rd Gear
Pilot bushing kit for 7.3L-ZF6
Hi,
I am getting ready to do some work on my 2000 F-250 PSD with the 7.3L and ZF6 transmission. I would really like to buy one of these kits if possible so I can replace the clutch at the same time. Can you please contact me if available or if youknow when they might be available again?
Many Thanks,
Jamie Austin (Shadetree68)
shadetree68gto@gmail.com
325-650-6712
Old Jul 20, 2024 | 08:26 PM
akcooper9's Avatar
akcooper9
Originally Posted by Shadetree68
Hi,
Many Thanks,
325-650-6712
Hey Jamie
They are available. Here is where you can buy them: https://www.builtbyahigherstandard.c...-pilot-bearing
Old Jul 20, 2024 | 08:38 PM
Shadetree68
3rd Gear
Sir, you are my hero. I have been following the series of forum leads on this for hours.
May your beer always be cold, and your cooler never empty!
Jamie
