1973-1979 FORD TRUCK PARTS
For SaleMiscellaneous
Description:
parted out many ford trucks parts 1973, 1974, 1975, 1976, 1977, 1978, 1979, f100, f150, f250, bronco
Locking hood latch-three pieces.1 latch with cut cable,1 lock with cut cable,1 NOS D5DZ-16914-A cable handle lock
kick down rodS
D5DE 12127 distributer A 4H21
NOS Ford OEM Auxiliary Transmission Mount Insulator NOS B4q-7010-b 64 - I have two of them
NP435 TRANSMISSION TOP COVER SHIFTER MOUNT WITH FORK AND SHIFTER
door panels, deluxe with trim
IGNITION MODULES
D3TA-13B302-AB Turn Signal Switch Fits: 73-77 F100-350 w/ manual transmission,75-77 E100-350 w/ manual transmission,74-77 M450 500 w/ std. steering
Tailgate Latch - right - 1973-79
302/351, 240, 300, 360, 460 engine stands perches
air cleaner duct D3TF-9a 624 aa, D7TE-9A624 DA, D8TE-9C604 BA
Am working radio
front stabilizer
good pair of fenders
CB --- AM/FM splitter to allow CB to use the factory AM/FM antenna
front fender racetrack trim
inner fenders
radiators
power steering bracket for column collar at firewall
300 CRANK PULLEY FOR POWER STEERING
shop manual three volume set volumes 1-45 1977
Power Steering gear boxes RF D7TC-3550-CA 4 WHEEL DRIVE. D1tr-3550-BA 2wd F150/250 box with pitman arm D2TA-3590-BA
Air cleaner air intake tube assembly D3TF-9A624 AA, D7TE 9A624 DA, D8TE-9C604-BA
saddle tank shield
1978 ford f150 4x4 booster and master cylinder brackets
Full set of long bed and cab and fender and door dent side trim with rubber insert
302 D3OA-9425-AA intake
wire harnesses 1979, 1978, 1977
Steering column parts and wheels,
1973-1979 FORD SHORTBED RAILS
FENDER SHIELD & HINGE SUPPORT, REPAIR 1973-1979 inner fender TRUCK BRONCO. brand new
2 wheel drive 1976 f250 rolling frame
vents, vent hoses, blend door units heater box, dash bezels, dash, heater fans and boxes,
LMC truck horn new in box 36-2150 low
T18 bell housing for 300
D1TA-8394 aa manual bell housing 1971-76 FORD 4-SPEED BELL HOUSING 300/302/351W and shift parts. Z bar, equalizers, etc
D1TA-6394-AA. Per the internet, this bellhousing fits the 302 cylinder V8 engines and truck 6 cylinder engines in the early 70s. May fit other models and years.
STARTERS:
352 manual transmission C5AF-11131
D0of 11131 b 302 manual transmission,
D0af-11131 b, 302 manual transmission
390/360 starter
D2af-11131-ca, 289-302 auto
windshield washer reservoirs
two sets of map pockets doors xlt ranger
dash Bezels including a radio delete
Air cleaners
Air horn tanks
302 engine parts-heads and engine parts/, 240 block, cam. pistons
Headliner trim super cab and regular cab
door and window parts, windows
360/390 fan radiator shroud
hood locking latch
BELL HOUSING FOR 300, ring gear and clutch
Super Cab rocker trim
narrow and wide dent side trim
Exterior trim, grills, and grill inserts, bed trim, cab trim
Dash,
power steering pumps
ford motor company hub caps/wheel cover
LMC 40-0834 Hex nut 73-79 flareside. new in bag
RED DOOR POCKET
302 exhaust manifolds:
C4OE 94030, C4OE 9430 A, C5AE 9491 B, D3DE 9431 EA, D5DE 9430, D3DE 9431 EA, D5DE 9430 BD, D1AE 9431 BB, D1OE 9430
Various cables, emergency brake and speedometer cables trucks. 1973, 1974, 1975, 1976, 1977, 1978, All are in working order
carburetor spacers
D3TZ-17752-A Right & D3TZ-17753-A Left .. Front Bumper Brackets 1973/77 F250 4WD & F350.
AM radio Motorola . Model 5FIRAM8. 15D41133D01
fenders, trim, electrical, ignition module, flareside parts, body parts, frame parts,
Carburetor rebuild kit Holley model 1940 50-420-1 15507a elchlin, NAPA new in box
1978-1979 grill inserts
Engine perches 1965/67 F100/250 2WD 240/300/352 / 1968/72 F100/250 2WD 240/300/360/390 / 1973/76 F100/250 2WD, F350 240/300/360/390 / 1977/78 F100/250 2WD & F350 300. Engine perches 400, 302 perches SBF
intake manifold gasket set new MS 90145 Fel Pro
valve cover set new VS 13049 C Fel Pro
Flareside (stepside) license plate holder and light
Flareside (stepside) tailgate chains
Brand new replacement metal patch panels:
Bed rear post 1967-1979 right side TGP-3-R Schott panels
body replacement panels for fender
cab mount replacement panels from rock auto or jegs
bed inner wheel well
Cab mounts
lower fender panel
Much more stuff.
1971-1979 Ford Galaxie 500 Ltd Pinto Radio **** D1aa-18a932-aa
NOS dome lens in box D1AZ-13783-B 1971-79 Ford Mustang, Torino, Ranchero, Cougar, Comet, Bronco
