2017-19 Super Duty 8" Instrument Panel Cluster (IPC)
For Sale
Miscellaneous
  • Miscellaneous - 2017-19 Super Duty 8" Instrument Panel Cluster (IPC) - Used - -1 to 2026  All Models - -1 to 2026  All Models - -1 to 2026  All Models - Clear Spring, MD 21722, United States
    Expired
    Expired
  • Price
    $325
  • Location Clear Spring, MD, 21722, USA
  • Condition Used
Description:
  •  Nice condition 8" IPC for sale. Has ~108k. Programming can be done via FORScan to match your current vehicle setup. (Note that mileage can only be adjusted upwards via FORScan. FORScan can adjust engine and idle hours upwards/downwards.)
  • Brand new OEM lens installed. Totally scratch free.
  • Unit is for the 6.7 diesel (the tachometer is different between the diesel and gas units).
  • Free shipping to lower 48 states
  • If you're not comfortable doing your own programming, member Livingitup does full programming and I can direct/drop ship the IPC to him for you.
Old Jan 26, 2025 | 03:02 PM
Vicstruckservice's Avatar
Vicstruckservice
Trailering
Instrumental cluster upgrade
Hello, coming across post on the instrumental panel cluster upgrade. I have a 2017 F250 xl and I am looking to upgrade mine to A8 inch display, like you have advertised for sale.What all is involved and do I have to do a lot of modifications to do this upgrade
Old Jan 26, 2025 | 06:24 PM
h20camper's Avatar
h20camper
The swap is easy. The programming requires FORScan. Unit I have has 108k so if your truck has more miles, you can update the mileage.
