1987 Ford F-250 XLT lariat with 62k Original miles and paperwork.
For Sale1987 Ford F-250
Price
$1
- Location San Diego, CA, 92129, USA
- Condition Used
- VIN 1FTHX25L3HKA50906
- Mileage 62,000
- Engine 8 cyl
- Drive Type 2WD
- Transmission Automatic
- Vehicle Type Truck
- Exterior Color Blue
Description:
** you may call/text to: 202 four41 six444**
1987 Ford 1987 Ford F-250 XLT lariat
Paint color: Ford light Regatta Blue and colonial white
Interior : Blue cloth
Mileage: less than 62000 (original miles)
Engine: 7.5 (460), carbureted with Holley carburetor.
Transmission : automatic
Drivetrain : 2x2
Currently smoged and registered in CA.
Truck is located in San Diego CA.
In August of 2022, I acquired this Ford-F-250 from the original family who had been the sole owners since new. I have documentation, including ownership and service records, that can be provided, tracing back to its origin at Heller Ford Escondido, CA. This particular truck has accumulated 62,000 miles, and has received meticulous care and maintenance from both the original and current owners. Notably, this vehicle has predominantly served as a family car since 1987, rather than being employed as a work truck. While it exhibits a few expected small paint imperfections due to its 36-year lifespan, there is no rust present. The interior remains in pristine condition, and the engine bay appears clean and well-preserved. Moreover, the truck has been repainted in its original color by its previous owners. It is essential to emphasize that this truck retains all of its original factory equipment, which functions flawlessly. A recent 900-mile round trip was completed without encountering any issues, highlighting the exceptional driving performance of this vehicle.
Regarding smog compliance, this truck has been based in California since its initial purchase and is currently registered and smog in CA. Smog reports for the past 15 years are available as evidence of its consistent passing CA smog. Furthermore, it should be noted that this truck is a factory non-catalyst model, meaning it does not possess a catalytic converter. As a result, it is exempt from catalytic converter requirements in California, making it highly desirable. This exemption also enables the freedom to update the entire exhaust system, as exhaust components are excluded from smog inspections.
Below is the most recent (less than 2000 miles) maintenance history by the current owner.
- New four Tires : Falcon Wildpeak A/T3W - LT235/85/16
- New Starter motor and starter solenoid
- New Holley carburetor
- Oil changed with Motorcraft Synthetic blend 5w-30 motor oil & Genuine OEM Motorcraft FL1A Engine Oil Filter
- New Window regulator
- new OEM Motorcraft temp sensor
- New OEM Ford Midship fuel pump and sender
- New OEM Ford fuel pump and sender
- F&R Fuel Tank Vent hoses
- F&R Fuel Tank Vent seals
- Monroe shocks and struts gas magnum 34963 shocks
- Moog K80017 stabilizer bar link
- Moog K80017 stabilizer bar bussing kit
- Valve cover gasket set
- Fuel vapor Valve Seal
- new Check valve
- new Coolant Reservoir
- New OEM Ford motorcraft Oil filter breather cap
- Fresh Air Intake Hose system
- Crankcase Breather Element pro grade
- Ford Air cleaner wing nut
- New Carburetor Preheater Hose
- New Ford Hood to Cowl Seal
- 56703 miles: new belts, Alternator replaced less than 5000 miles ago.
- 55908 miles: EGR gasket, Fuel pump, spark plugs and rotor , vacuum Advance control
- 50659 miles: water pump, timing cover front
