Dual piston front disc brakes or backing plates .
Wanted
Brakes
  • Brakes - Dual piston front disc brakes or backing plates . - Used - 1969 to 1979 Ford 3/4 Ton Pickup - San Diego, CA 90706, United States
    Expired
    Expired
  • Price
    $0 - $1
  • Location San Diego, CA, 90706, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford 3/4 Ton Pickup 1969 - 1979
Description:
I have not seen a lot of 69-79 F250 disc brake set ups except the one I need .
I know around 76 they came out with a single position style  although I am not sure if  the backing plate pattern is the same as my 69 4 bolt square .
THe backing plate pattern is the same on the disc brake I need in picture as with my 2.x 2.5 drum brakes so I can use my 69 spindle and just use the backing plate for the dual piston disc set up , here is the part I need ..
Old Feb 5, 2024 | 09:43 AM
SoCal69's Avatar
SoCal69
No longer needed .
