3D Printed Adaptive Cruise Control Module Bracket 2020-2022
For Sale
Miscellaneous
  • Miscellaneous - 3D Printed Adaptive Cruise Control Module Bracket 2020-2022 - New - 2020 to 2022 Ford F-250 Super Duty - 2020 to 2022 Ford F-350 Super Duty - 2020 to 2022 Ford F-450 Super Duty - Greenville, NC 27858, United States
    Expired
    Expired
    Expired
    Expired
  • Price
    $30
  • Location Greenville, NC, 27858, USA
  • Condition New
  • Compatibility
Make Model Year
Ford F-250 Super Duty 2020 - 2022
Ford F-350 Super Duty 2020 - 2022
Ford F-450 Super Duty 2020 - 2022
Description:
Hello.
I am offering my 3D printed Adaptive Cruise Control Module Bracket for sale to FTE members. This bracket offered for sale is my 7th revision of this part is a near replica of P/N LC3Z-14C022-C. The bracket allows for adjustment the same way as the OEM part would and is 3D printed by me using ASA filament. ASA is a type of plastic very similar to ABS which is commonly used in automotive applications. ASA plastic is dimensionally accurate, impact resistant, heat resistant, chemical resistant, and UV tolerant. The cost is $30 including Priority Mail shipping.
To utilize my mount/bracket you'll need to follow these instructions:
  1. Remove the 3 plastic retaining clips on the ACC module. Note: these clips are pressure fit on and are a bit tough to remove.
  2. Place the ACC module on the indexed standoffs incorporated into the bracket.
  3. Tighten down with 3 M8x20mm bolts. Note: Longer bolts can be used in conjunction with a nut if you're concerned about the bolt backing out. However, in my experience the plastic-on-metal contact of the bolt prevents the nut from backing out. I just wanted to note that this option is available.
Matches OEM fitment and adjustability. This mount also contains countersunk holes for the OEM adjusting bolts. At the time of writing this, LC3Z-14C022-C (The OEM part my 3D printed part replicates) has been on national backorder for nearly 6 months and is $68 before shipping/handling/tax.
Thanks!
Old Mar 5, 2023 | 08:23 AM
Ry Guy's Avatar
Ry Guy
I used this bracket for my install and it worked flawlessly. You can see the details here. Highly recommend.
Old Mar 8, 2023 | 09:43 PM
jrx13's Avatar
jrx13
This bracket works great and it's a great price! Get it!
Old Apr 11, 2023 | 07:43 AM
Jeogbl68's Avatar
Jeogbl68
4wd Low
Hello, I would like to purchase one of these brackets. Are they still available?
Old Apr 11, 2023 | 08:51 AM
RapidRed7.3's Avatar
RapidRed7.3
They are. PM sent.
Old Apr 11, 2023 | 04:42 PM
Jeogbl68's Avatar
Jeogbl68
4wd Low
Quick question, did you guys use a tap to thread the holes in the bracket or just use the M8x20mm bolts?
Old Apr 11, 2023 | 06:25 PM
RapidRed7.3
I print the holes a couple tenths of a mm smaller than 8mm and tap the holes with a scorching hot M8 bolt before I ship the bracket out. That way if something goes awry it's on me.
The bracket you'll receive will be ready to install with threads tapped.
Old Apr 28, 2023 | 09:16 PM
MattyFatty's Avatar
MattyFatty
I'm not sure why I can't send a PM, but I'd like to buy one of these if possible!
Old May 9, 2023 | 12:21 PM
mbarrera872000's Avatar
mbarrera872000
1st Gear
Would love to purchase this product if you still have some available.
Old Oct 2, 2023 | 01:06 PM
bigvic48's Avatar
bigvic48
4th Gear
Interested in purchasing one of these. PM sent.
ETA, looks like I'm too new to send a PM. Please PM me a way to get in touch if you still have these for sale.
Old Jan 11, 2024 | 01:02 AM
DFSDude's Avatar
DFSDude
6th Gear
I've still got a couple days to pm(forum newbie)
I will be sending a PM soon if these are still available when my account is fully active here.
Old Jan 25, 2025 | 11:56 AM
RoMeinRoMe's Avatar
RoMeinRoMe
5th Gear
Hi, I would like to purchase this from you, but can't send a DM. If you can reach out to me through DM I would greatly appreciate it, or you can text me 504 four five one 83 seventy five. Thanks!
