69-79 F250 disc brakes and parts wanted
WantedBrakes
Description:
Hey guys I'm looking for a set of disc brakes off a 69 to 79 Ford F-250 3/4 ton
I at least need the left and right backing plates that hold the calipers on everything else I can buy new, although if the calipers are good and the rotors can be turned I would be interested in the whole set.
I currently have a 69 Ford f250 camper special with power drum brakes so the minimum parts that I need is the backing plates that hold the Dual piston calipers on thanks I'm located in Southern California.
