FREE Air Cleaner with Heat Control Snorkel for Single Barrel Carb
For Sale
Engine - Intake/Fuel
  • Engine - Intake/Fuel - FREE Air Cleaner with Heat Control Snorkel for Single Barrel Carb - Used - 0  All Models - Boulder, CO 80305, United States
    Expired
    Expired
    Expired
    Expired
    Expired
4wd Low
  • Price
    $0
  • Location Boulder, CO, 80305, USA
  • Condition Used
Description:
Air cleaner assembly that came off my 1985 F150 with the 300ci 6cyl. This is definitely not the factory air cleaner, the previous owner had removed the computer controlled carb set up and replaced it with an older Carter YF. I moved to a bigger carb so this is of no use to me. The mounting hole is 2 5/8". Overall is about 15" across and 3 1/2" tall with a concave base. The filter is 9 1/2" ID x 2" Tall. The snorkel is ~10" long. The heat control flap vacuum can works great and does not leak. The cover has a temperature control vacuum valve already installed and I have an extra that I will include as well as the vacuum check valve that is installed in the hose between the temperature valve and vacuum can. I cannot find any part numbers on the assembly.
Lots of details on Garagemahal on why you want this part, somewhere in there Gary jokes that if you still want to trash yours to mail it to him. https://www.garysgaragemahal.com/air-cleaners.html
Part is FREE and located in Boulder, Colorado. I am happy to ship it at your expense.
Old Jul 12, 2023 | 08:02 PM
herdfan75's Avatar
herdfan75
Is this still available? I know the ad is old but you never know. If so, how much shipping to 25202? I put an older style YF carb on my son’s 86 F150 300 I6 and we don’t have an air cleaner. Thank you!
Old Jul 12, 2023 | 08:47 PM
nickfjields's Avatar
nickfjields
4wd Low
I do still have the part and you're welcome to it, sent you a private message
Old Jan 12, 2025 | 07:25 PM
reverethewise's Avatar
reverethewise
1st Gear
Still available?
Still got this? Please reply or PM
