2003 Ford Excursion
For Sale
2003 Ford Excursion
  • 2003 Ford Excursion - 2003 Ford Excursion - Used - VIN 1FMNU45S03EB13025 - 246,927 Miles - 10 cyl - 4WD - Automatic - SUV - White - Williston, ND 58801, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
  • Price
    $4,000
    • OBO
  • Location Williston, ND, 58801, USA
  • Condition Used
  • VIN 1FMNU45S03EB13025
  • Mileage 246,927
  • Engine 10 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color White
Description:
2003 Excursion V10 4x4 Eddie Bauer.
Runs good doesn’t burn oil.
the engine had been replaced sometime before I purchased the excursion, however I do not have details on it.
has a stinger High 10 floating display head unit installed.
also the factory dash was not cut to install this unit like most dashes are cut for two din unit.
has a prodigy p2 brake controller.
Tires only about 6 months old.
Falcon Rubitrek tires 265/75R16
has the hard to find factory 6 hole wheels.
I drive it very little as I have a work truck that I use for my work commute.
The drivers seat has typical 19 year old wear, however I have a good set of seat covers that come with it.
The Excursion also comes with a set of B code rear springs, and a set of V code front springs with an add-a-leaf. I have shims for the axles that I have not yet installed, to go along with the spring lift.
installed on the factory Dana 50 is a set of Warn premium locking hubs.
If you would prefer the auto lock hubs it comes with two sets, and the factory vacuum system is intact and working.
the front Dana 50 was rebuilt with all new vacuum seals and timkin wheel bearings 2 years ago. Also to come with a fitting for greasing the front unit bearings, made by one of the members here.
Also have 2 Dana 60 front axles and a 10.5 Rear axle to go with it.
this way you can build your axles up before swapping them into the Excursion.
asking $4000
call or text 701-770-seven two five three
Old Mar 1, 2023 | 05:12 PM
ShelS's Avatar
ShelS
8th Gear
I'm guessing this sold already?
Old Mar 1, 2023 | 09:39 PM
Ogre20012001's Avatar
Ogre20012001
You are correct
I forgot this ad was still here
I’m sorry for the inconvenience
