78 F150 short bed
For Sale1978 Ford F-150
Price
$5,000• OBO
- Location Manassas, VA, 20110, USA
- Condition Used
- VIN F14HNC00791
- Mileage 160,000
- Engine 8 cyl
- Drive Type 4WD
- Transmission Automatic
- Vehicle Type Truck
- Exterior Color Black
Description:
78 F150
4x4
Auto
short bed
351
lots of miles about 160000
truck has been in Virginia it’s whole life
i drive it just about every weekend.
needs TLC
needs a Good tune
parts replaced in the last 2 years
entire brake hard lines in stainless steel
inline rube
drop chassis hose to axles
New proportioning valve
new calipers
new rear hydraulic cylinders
new drums
New master cylinder
new carb
new 38 gallon tank
new 38 Gallon sending unit
new rubber hoses for fuel line
new fuel filter
new fuel filler rubber hose to gas tank
new rubber vent gas tank hose
new glow shift gauges
tach
oil pressure
water temp
new cap rotor and plugs
from precision rubber products
new rubber window seals
new window anti rattle rubber
Door seals not installed yet
New rubber seal over top of door not installed yet
new seat cover
the actual seat cover is in dire need of repair.
4x4 works properly
again needs a good tune and timing setting.
Asking $4500
only trade for CASH.
4/30/2022 Update:
New Flow Kooler Water pump
New Mufflers
New Water temp sensor for stock dash
Hope to get them in next weekend.
New Radiator 3 Row Aluminum.
Super cooling larger size
Also has a fan shroud for 4 12 inch Spal fans.
Not sure when that will go in.
Radiator electric fan controller fron The Auto Cool Guy.
Not sure I am going mechanical or electric as of yet.
