WHO WANT"S A 460
For Sale
Engine - Complete
  • Price
    $600
    • Trade
  • Location Lewiston, ID, 83501, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford Any Model Any Year
Description:
Here's the deal I have 71 block 460 that was supposed to go into a project my son was doing, he opted to keep the 400 in it.
It came out of a 78 super cab 2wd, at some point it had been rebuilt it ran 135 psi compression with D3 heads and had 60psi of oil pressure. It had a broken valve spring on #8 exhaust if I remember correctly.It has all the right brackets and exhaust manifolds for a pickup the only thing you would need is mid or rear sump pan and pickup to put it in a 4x4. With a broken valve spring this thing ran amazing you only new it had a miss at an Idle. So the deal is I will give all of it to who ever wants it! The caveat Is I have a set of dove heads and a scj intake that go with it and yes the casting # is D0oe! those aren't free and if you want the engine you take the intake and heads for 600.00. I live in Idaho Any questions just ask! I don't get on here a lot any more but will try to check for messages at least once a week. Thanks Alan
Old Jul 12, 2022 | 09:48 AM
MattRelling82's Avatar
MattRelling82
1st Gear
Drooling
[QUOTE=alans77crew;20143324]Here's the deal I have 71 block 460 that was supposed to go into a project my son was doing, he opted to keep the 400 in it.
It came out of a 78 super cab 2wd, at some point it had been rebuilt it ran 135 psi compression with D3 heads and had 60psi of oil pressure. It had a broken valve spring on #8 exhaust if I remember correctly.It has all the right brackets and exhaust manifolds for a pickup the only thing you would need is mid or rear sump pan and pickup to put it in a 4x4. With a broken valve spring this thing ran amazing you only new it had a miss at an Idle. So the deal is I will give all of it to who ever wants it! The caveat Is I have a set of dove heads and a scj intake that go with it and yes the casting # is D0oe! those aren't free and if you want the engine you take the intake and heads for 600.00. I live in Idaho Any questions just ask! I don't get on here a lot any more but will try to check for messages at least once a week. Thanks Alan[/QUOT
do you still have
Old Jul 30, 2022 | 01:18 PM
Eber/Brasil's Avatar
Eber/Brasil
3rd Gear
Hi, I'm rebuilding my 69 T-bird and I need a DOVE block. My car has a C9VE-B engine and C9VE-A cylinder heads. Now, we find that the block has a crack, reason for the exchange. I await your contact. Even though I'm in Brazil, you can send it to a warehouse there in the US and they send it to me here. I am waiting. Thanks. Eber
Old Nov 9, 2023 | 11:14 AM
Questions12's Avatar
Questions12
4wd Low
Any pictures of the Engine? I live about 2 hours away and interested in buying.
Thanks
Old Dec 8, 2024 | 04:49 PM
Kawtheman's Avatar
Kawtheman
2nd Gear
I’m interested in ur motor plz reach out asap
