Many Excursion Interior Parts, Barn Doors and More
For Sale
2001 Ford Excursion
  • 2001 Ford Excursion - Driver side barn door - Exterior Body Parts - $300 - Milwaukee, WI 53213, United States
    Expired
    Expired
    Expired
    Expired
    Expired
  • 2001 Ford Excursion - Passenger barn door - Exterior Body Parts - $300 - Milwaukee, WI 53213, United States
    Expired
    Expired
    Expired
    Expired
    Expired
  • 2001 Ford Excursion - Factory rear bumper with backup sensor holes (2 sensors and harness) - Exterior Body Parts - $400 - Milwaukee, WI 53213, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • 2001 Ford Excursion - ABS module - Manifold and Controller - Brakes - $400 - Milwaukee, WI 53213, United States
    Expired
  • 2001 Ford Excursion - GEM - Miscellaneous - $500 - Milwaukee, WI 53213, United States
    Expired
    Expired
  • 2001 Ford Excursion - Backup sensor module labeled 2X4 - Accessories - $100 - Milwaukee, WI 53213, United States
    Expired
  • 2001 Ford Excursion - Third Row Seat - Interior/Upholstery - $400 - Milwaukee, WI 53213, United States
    Expired
    Expired
    Expired
    Expired
  • 2001 Ford Excursion - Factory running boards - SURFACE RUST ONLY - Exterior Body Parts - $400 - Milwaukee, WI 53213, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
Description:
PM ME IF YOU WANT A PART! That notifies me much sooner. I rarely check this thread for inquiries.
2001 Limited 2WD
Body color: Chestnut Brown (Code B4)
Interior is tan (Medium parchment code LH)
Southern truck never saw winter salt. No deep rust, only surface rust.
DELIVERY/SHIPPING: I'm always up for a road trip so PM me to make arrangements for the bigger pieces. For large items, I can also palletize and ship if desired.
Huge list here:
A bunch of the tiny interior panels, plugs, bolts, etc. that normally get lost in a wrecking yard. PM me for specific pieces you may be looking for.
ABS module
Factory running boards tan/beige
GEM
Steering box
Driver side middle row door with power window and door panel (no bottom weather strip)
Passenger side middle row door with power window and door panel (no bottom weather strip)
Third row seat (tan)
Middle row 40% jump seat (tan)
Rear driver side window (with motor)
Rear passenger side window (with motor)
Rear passenger barn door with latch and interior panel (no hinges, no weather strip)
Rear driver side barn door with latch and interior panel (no hinges, no weather strip)
Rear lift gate hatch with hinges and wiring harness (no glass)
Rear bumper with backup sensor holes. Includes 2 sensors and complete wiring harness. (no license plate lights)
Third row kick plate (tan)
Washer fluid tank and pump
Front row seatbelt adjusters
Middle row shoulder seat belts (both sides)
Middle row seatbelt adjusters
Rear row shoulder seat belts (both sides)
Rear AC/Heater unit with blend door system and blower fan
Driver power seat
Center console includes rear headphone and volume controls (no lid)
Second row manual climate controls
Dash manual climate controls
    Interior panels (almost every piece available)
    Rear driver side quarter panel interior panel
    Rear passenger side quarter panel interior panel
    Driver side B pillar  interior panel
    Passenger side B pillar interior panel
    Driver A pillar interior panel
    Passenger A pillar interior panel
SOLD - Middle row overhead lights (both sides)
SOLD - Rear row dome lights
SOLD - Rear hatch dome light
Rear hatch interior panels (Lift gate)
All grab handles with screw plugs
Seven pin hitch plug and harness plug
Rear tail lights
Added to list:
Front passenger solid metal brake line (line from ABS to rubber passenger brake line)
Brake lines from master cylinder to ABS
Driver lock and window controls (switches) and mounting panel
Dash slide out cup holders
Picture Title Part Category Price Part Description
Driver side barn door Exterior Body Parts $300 Good condition, light scuffs. Includes interior panel and latch.
Passenger barn door Exterior Body Parts $300 Good condition, light scuffs. Includes interior panel and latch.
Factory rear bumper with backup sensor holes (2 sensors and harness) Exterior Body Parts $400 Great condition with light surface rust on the inside only. Includes two sensors and the backup sensor factory harness.
ABS module - Manifold and Controller Brakes $400 Came off working truck. Was wrapped and sealed immediately after removal to keep internals clean
GEM Miscellaneous $500 Came from working vehicle before it was wrecked.
Backup sensor module labeled 2X4 Accessories $100 Came from working vehicle.
Third Row Seat Interior/Upholstery $400 No holes, tears, significant wear in the leather. It's in good, usable condition. Wheels (used when removed) are in excellent condition. Likely never taken in and out. Some dirt and scuffs (has not been cleaned).
Factory running boards - SURFACE RUST ONLY Exterior Body Parts $400 Came from a southern truck. No deep rust, only light surface rust on 20 year old exposed parts. See pics.
Old Oct 20, 2021 | 08:49 PM
Rocksanne's Avatar
Rocksanne
Console?
Hi. I would buy the whole console of required, but I just need the rear audio control unit. Please let me know. Thanks.
Old Oct 21, 2021 | 01:55 PM
jasonodsky's Avatar
jasonodsky
Looks like you can't PM yet. I replied to your visitor message on my profile with a way for you to contact me.
Jasonodsky
Old Oct 21, 2021 | 08:19 PM
Jregezeino's Avatar
Jregezeino
Interested in the passenger side D pillar trim ( the one with the circle of holes in it for the backup sensor speaker ) as long as the mounting tabs are good.. Also the Drivers side C pillar Trim, with the same caveat.
How much for the GEM?
Im local in Mukwonago...Thanks, Jon
Old Oct 24, 2021 | 08:54 PM
jasonodsky's Avatar
jasonodsky
I PM's you with my cell number so we can connect. I confirmed the two interior panels have all the mounting tabs intact and can pics. Only caveat is driver C pillar is missing the tiny bottom hook that connects to the rear quarter panel trim (that always seems to break the first time you remove it) I can send pics.
Old Oct 24, 2021 | 08:55 PM
jasonodsky's Avatar
jasonodsky
Please PM me with a way to contact you so we can connect. I would sell the audio control separate. I can send pics once we connect.
Old Dec 8, 2021 | 03:58 AM
MightyDuc's Avatar
MightyDuc
4wd Low
Any chance you have the driver's seat trim panel (the piece where the adjustment controls and seat heater are located) and willing to part with it? Thanks in advance for the info!
Old Dec 8, 2021 | 02:25 PM
jasonodsky's Avatar
jasonodsky
Yes, I have that trim panel but I don’t think it has the seat heater switch hole. Though it may have a blank plug in that spot. PM me with contact info so I can text you a pic of the part to confirm if it’s right.
Jasonodsky
Old Feb 11, 2022 | 01:38 PM
dovehuntingfool's Avatar
dovehuntingfool
Jasnodsky,
Dovehuntingfool here, in need of 3rd row seat Ford Ex. Please e-mail me at sam@precisionairtechnology.com. I am in N Carolina but will road trip also..
Old Feb 13, 2022 | 08:36 AM
dovehuntingfool
Excursion Third row seat
Jason, dovehuntingfool here. I’m still interested in the 3rd row seat for the Ford Ex. My e-mail address is sam@precisionairtechnology.com. I am in NC but I don’t mind a road trip either. Shoot me an e-mail and we can connect!
Sam
Old Feb 14, 2022 | 03:03 PM
jasonodsky's Avatar
jasonodsky
@dovehuntingfool I just sent you an email from my gmail. I included my cell so we can connect. Go ahead and edit out your contact info on your post.
Jasonodsky
Old Feb 14, 2022 | 09:02 PM
Don Naslund's Avatar
Don Naslund
Overhead sunglasses storage.
Old Feb 28, 2022 | 12:53 PM
blageurt's Avatar
blageurt
Ashtray Assembly ( Astray and Mounting Bracket )
Old Feb 28, 2022 | 01:07 PM
jasonodsky's Avatar
jasonodsky
Are you looking for the ash tray that Ford later replaced with the trash bag hook? If so, I don't have one, sorry.
Jasonodsky
Old Feb 28, 2022 | 03:14 PM
WI Dan's Avatar
WI Dan
Jasonodsky
I have a pull-out ashtray assembly from my 2000 Limited. Deep brown colored. Interested?
