1973 Ford F-100 Ranger – 360 FE w/ C6 Auto – 135k miles – Clean Title
For Sale1973 Ford F-100
Price
$3,500• OBO
- Location St. Louis, MO, 63114, USA
- Condition Used
- VIN F10YUR60469
- Mileage 135,000
- Engine 8 cyl
- Drive Type 2WD
- Transmission Automatic
- Vehicle Type Truck
- Exterior Color Other
Description:
Moving across the country and have to sell my current project. Tons of work already done to this awesome Medium Lime Metallic F-100 ranger with factory A/C. Lots of extra parts already purchased and included in the sale. I bought this truck with no intentions of ever selling it so all work has been done with top shelf parts and with a full restore in mind.
Just cant justify the cost to ship it across the county. Below is a list of what's done, what's purchased and what is still needed. Truck runs and drives as is, strong 360FE big block, smooth shifting auto C6 and steers well with a fully replaced steering setup.
Completed: HVAC blower motor, HEI distributor, Performance plug wires, Spark plugs, Valve seals, All new ignition wiring, Long tube headers, Master cylinder, RedHead steering gear, Tie Rods, Center Link, Restored power steering pump, Alternator, Rebuilt 2100 Carb, Eldebrock air cleaner (Factory air cleaner included), Cab running lights, All new vacuum lines, Transmission solenoid
Purchased parts included: Performance timing set with dual chains, Water pump, Motor mounts, Transmission mounts, New gasket for every gasket on the truck (already installed valve seals and valve cover gaskets), Axle pivot bushings, Control arm bushings, Cherry bomb mufflers (currently strait pipes with under cab dump), Cab mount
Work needed: Install drivers side cab mount, New floor pans, A/C needs charged (Switched to R-134 already)
