1966 F100 Straight Six Radiator
For SaleMiscellaneous
Description:
Straight six specific radiator for Ford F100, F250, F350 from the 1960’s (slick side). It may also fit trucks up to 1972 with a straight six.
The straight six motor uses a smaller inlet and outlet then the V8 radiator. The lower outlet is also on the passenger side. Removed from a truck that had a 300ci motor from the factory. Will work with the 300ci or 240ci motor.
Good condition, worked fine, cooled fine, no holes or visible repairs. Does have a tag on the back to make me believe it was re-cored at some point. Also have the block off panel for the core support. I will toss the fan in if you need it as well. Only asking $50 for everything. If you are interested email me @ Petrol360media at gmail.
AlloyWorks sent out a new aluminum radiator to use with my build so I am letting this one go to someone who may need it.
Local pickup unless you car really twist my arm. Located east of Charlotte NC. South of Concord.
Can you please check the core measurements for me? 24 tall x 26 wide or 19 tall x 26 wide... or?
I have a 1974 F600 that someone stuck a 300 into & my radiator went out. While I'm looking for a 391 FT I still need to use the truck so a used rad would get me by until I can swap to a v8 which would need a different radiator anyhow.
I'm in Virginia but drive thru Charlotte often. Sending email.
Taken from a place that sells aftermarket rads. MOST of the measurements on this one match mine except my core height is about 24 inches & the over all height is about 5 more inches than this.
