I have a number of Rebuilt ZF S5-42 and S5-47 manual transmissions for sale. I’ve been a Ford mechanic for 25 years and rebuild these in my spare time for extra cash. Cases are hot washed and checked for cracks. Any worn gears or worn engagement surfaces are replaced. All bearings and synchros are replaced. Shift forks are replaced. Cases are sealed with three-bond and don’t leak. I’m meticulous.
I am looking to swap the auto tranny on my 2001 F350 to a manual.
Do you have one?
I will need everything:
Transmission, manual 4x4
Transfer case
Cross member
drive shaft
pedal assembly
slave cylinders and line
Looking for a zf5 that will bolt up. My transfer case is junk, but I can rebuild that myself if I have to. Been in it before. But I'd love a solid zf5 for my truck. I saw the swap online and love it. All I have to offer is a working m5r2 that needs at least one bearing and synchronizers. Any help you can offer would be great but I think shipping would be a killer though...
I figured. I love this little truck, but I want it done right. Seems in my area people r so stubborn they'd prefer to let 8 vehicles rot away in their front yard than sell one. It's such a shame.
Hi I I would like to purchase a transmission from you. I have a ZF 5-42 I would like to be able to discuss with you as I have a couple of questions. It would be great if you could give me a call at 971-201-6247 Alan Garrison thank you
Hi.. I've got a 2002 E350 powerstroke 4x4 with a ZF5/GearVendors manual tranny swap.. im looking for a wide ratio RMTS5-47-6 ZF5 to replace my existing tranny.. since I've swapped to 37's the 1st gear lugs a bit.. I'll be swinging thru california on my way to mexico.. can you help me with this??
cheers ZF5 / Gear Vendors OD The beast Laser scan inside Laser scan chassis Laser scan exterior Laser scan inside
