New 7/16 x 7/16 Screw In Studs
For SaleEngine - Internals
Description:
New never used 7/16(14) x 7/16(20) screw in studs. I ground off a bit of the top of the hex for additional aluminum roller rocker clearance. Added .30" addition thread to the top. Some measurements are as follows, bottom of hex to the top 1.78", bottom of hex to bottom .80", LOA 2.58". All measurements are as close as I could get. Some were temp mounted on a motor I was building, never run.
$23 + 11 USPS small flat rate box to lower 48 states.
