This 4x4 truck has always taken me where, I wanted to go & broth me back home since 1976
For Sale
1971 Ford F-250
  • 1971 Ford F-250 - This 4x4 truck has always taken me where, I wanted to go & broth me back home since 1976 - Used - VIN F26BRK09987 - 199 Miles - 8 cyl - 4WD - Manual - Truck - Blue - San Jose, CA 95139, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
  • Price
    $17,000
  • Location San Jose, CA, 95139, USA
  • Condition Used
  • VIN F26BRK09987
  • Mileage 199
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Manual
  • Vehicle Type Truck
  • Exterior Color Blue
Description:
1.BFG 10ply tires lots of tread on 16"x7'' Aluminum wheels tires LT285x7.5x16
2.AC under dash unit blows very cold r12 Freon
3.Aftermarket radio/flash drive plug.
4.New oem dash pad
5.Custom dash gauges
6.Holley Terminator EFI with new Edelbrock intake manifold
7.5spd overdrive dodge/Chevy NV4500 trans with all new bearings & seals
8.1976 Ft. axle with new disc brakes with lock-right internal gears with new locking hubs
9.Rear axle true track locker, sway bar 1.1/8" poly new brakes, new wheel bearings, seals
10.All new u-joints on all three drive lines front to rear new shocks with new bushings.
11.New tinted windshield with rubber seal updated stainless trim.
12.On board air 4gal tank with high output compressor 155psi aux air under hood & rear
13 Manual switched alarm door & hood, plus hood chained lock.
14 Spare tire crank-up & lowering hoist under rear.
15 Has Camper special bed with side tool box in bed.
16.New window & door seals
17.Has Trailer hitch receiver under front & rear bumper
18.Shoulder seat belts from 1998 ford Explore
19.Full cab new carpeting, inner roof & hood double insulation
20.Dual spot Aux lights & grille lights
21.Custom duel snorkel air filter
22.Aux compress air hose hook up front & rear
23.Dual batteries
24.110v 3k watt invertor aux plugs in front and bed rear box
25.Fairly new seat cover on 1976 ford seat with floor carpeting double padding
26.Upgraded transferase shift linkage
27.All new transferase seals & bearings with poly mounts 205 case up grade.
28.Eng.is 390ci D4TE truck block with a 428 crank bored.030 416ci mild RV cam
29.New 18 gallon fuel tank with new Holley duel switchable fuel pump or both feed
30.G3 130 amps G3 alternator dual V belts pulley upgrade
31.Super cool HD radiator with 19" clutch fan with shroud
32 New oem cab body mounts with all new cab oem cushions
33.Has 1975 truck Replaced radiator support with new cushions
34.has 1975 Front & Rear replaced springs and eye bushings
35.Has Led brake & front blinker lights
36.Head light cross over bypass power for brighter head lights
37.Back up aux back up lighting
38.Has cruise control for manual trans
39.In Bed aluminum tool box
40.Under hood extension core with crank up aux-light
41.New old stock replacement sliding rear window
42. Has D2 heads Stainless steel intake & exh. Valves smoothed port runner valve pockets
43.Dual air horns under both front fenders
44.Wiper 1979 delay upgrade
45.Body & tailgate side trim oem new trim
46.newly chromed head Liner trim
47.Steering replaced rebuilt OEM
48.Rebuilt power booster & master cyl.
49.HD Stage ll with a 11"clutch kit
50. The motor has 19k on it completely rebuilt block was squared bored 0.30 D4TE 105 mirror Block which is said to have thick cylinder walls. screw in oil plugs enlarge oil feed to cam bearings, chrome 6gt oil pan with windage tray, HD H beam rods, new rocker arms & shaft, mild RV cam, New Duraspark ll ignition upgrade Dist. with new Module box, HD oil pump drive rod. Exh system 2.5'' cross over with 14" 2014 mustang mufflers sound good.
Double roller timing chain. The internal engine block was completely deburred and painted with a specials electrical varnish used on armatures motors to fight rust almost like POR15 this reddish/brown paint $45 a qt. Has a new 11'' flywheel & ford stage 2 pressure plate and a Chevy 11" clutch dics matching throw out bearing. No rust or dents to repair. The floor pans had some rust a little few holes on both side which was repaired with fiber glass and POR15 was not bad enough to cut out the pan and reweld a new one in, the whole cab has been painted the black POR15 along with the radiator whole support front and back side and inner fender walls and the Fire wall were done with POR15 can't remember if, I had done the bottom underside of the bed or not or just used undercoating.
The Bad
Needs new tires the sun did them in. Sorry still has the stock manual steering as I hate bunch e  ring
Needs a new paint job, has some old bed trim holes needs filling bed side from old wide molding. I really hate to sell it but don't have a place to park it to many vehicles plus have a 40 ford that takes up any of my free time being a old fart now.. 3 vehicles don't get it now living in a apt complex
Old Aug 10, 2021 | 11:23 PM
ShaunRyan's Avatar
ShaunRyan
Did you ever sell this?
Old Aug 11, 2021 | 10:45 AM
orich's Avatar
orich
Yes was sold with 3 weeks of posting the ad should have a notice that was sold
Old Aug 11, 2021 | 11:48 AM
ShaunRyan's Avatar
ShaunRyan
Figured it must have but never hurts to ask. Awesome truck. Exactly what I need for developing a remote, off-grid mountain property.
Old Aug 11, 2021 | 12:37 PM
orich's Avatar
orich
Man it could have served you well with what i added
