Lots of New, unopened Engine parts and some Used truck/engine parts 99-03 Super Duty
For SaleMiscellaneous
Description:
Lots of unneeded parts both new/unopened and good used from my recent build.
All used parts off a 2001 F350SD and new parts for a 1999.5- 2003 Super Duty. Too many to post pictures but a list for you to PM me if interested.
Used parts that I have : 4R100 Trans ( won't go in reverse), Excursion rear gas tank (plastic with steel shield) with fuel lines ( where spare tire is located in pickups), 01 front bumper in real good shape (chrome). 01 header panel, 01 lights ( headlight unit is aftermarket and clear),
OEM Garrett turbo with Banks upgraded wheel and Big Head Westgate no visible damage or looseness ( approx. 100k ), Used but good bellowed up pipes, Used OEM HPOP (was working fine when pulled), really tired OEM 3 bolt starter,
Set of HD Eagle Eyes 07 Headlights ( New in box), Go od, undented rear bumper, DP Tuner ( N-Dash Monitor) with all cables ( working for 7.3 PID's),. Factory AM/FM CD Stereo Double Din unit (working),
THE FOLLOWING ITEMS ARE NEW UNOPENED PARTS: E3TZ-6A008-A 4X, Riffraff AIH Air Heater Delete Tapped Plug, Riffraff AIH Boost tube C-Fitting reseal Kit,
LPOP O-Ring XC3Z-6619-AA TWO Fuel Filter O-Ring with mesh filter, fuel filter O-ring, Riff-Raff HPX Line Replacement Adaptor 94-03, R iff-raff Filter cover gasket set YC3Z-6020-BAA,
Ford Parts Oil Pan P/U Tube Gasket F7TZ-6626-AAA 1XE ( 1 in box and 1 loose), Exhaust Back Pressure Valve Terminator and Sensor Eliminator(Stage 2) DF FUSER Part # (DFR-1002131 and DFR-1002018), Diesel Fuel sleeves on CVD Fitting GZ-7-004 (2), Diese l O Rings Replacement Fuel Pressure Regulator ( Billet Aluminum Housing with 3 fuel pressure springs, O-ring and mounting bolts Kit# 7-033, Diesel O Rings Turbo Pedestal 99-03 4 O-rings (Dupont Viton), Diesel O Rings GTP38 Turbo RE-Install Kit 99.5-03 Complete custom O-ring kit, Ford Motorcraft Poppet Seal Fuel Pressure Relief Rebuild kit F81Z-9B249-BB 1X, 2 Sets of OEM/Motorcraft Exhaust Bolts F4TZ9S425A 8X
Diesel O-Rings Vibra-lok Viton Seals 94-03 Fuel line sleeves (2), Diesel O Rings HIGH-FLO Fuel CVD Fittings (2), Die sel O Rings 99-03 COMPLETE Fuel Bowl Kit (Qty) 11 O-rings (qty) 4 sleeves Part# 7-003, Diesel O Rings HPOP Gasket 96-03 Part 8-009
OEM Fuel Filter 31749 ( I have 2 of them ), and Heavy Duty Fuel Filter lid O-ring Seals (5) part info: 400-347 Quattro Seals ( Improved Design seal ) . Riff-raff HPX line Replacement Adapter 94-03 Most all the new unopened stuff listed was purchased before I decided to go to a more expensive build and these parts were not used and only recently purchased. PLEASE PM ME for items and price your willing to pay. I can ship pretty fast if you e-mal me at bsiliani@yahoo.com and send payment via PayPal. If you send payment as a friend there is no fee involved and I'll send you shipping fee if you give me a zip code. I don't charge packaging fees or any excess shipping costs. I'll ship USPS, UPS, and if you need Fed EX. Either standard or expedited rates. I'll provide a tracking number as soon as I drop it off in system.
How much do you want for all of that? I live in 27239 zip code.
