1968 f250 390
For Sale1968 Ford F-250
Price
$5,000• OBO
- Location Trinity, TX, 75862, USA
- Condition Used
- VIN F25HRD03841
- Mileage 68,000
- Engine 8 cyl
- Drive Type 2WD
- Transmission Automatic
- Vehicle Type Truck
- Exterior Color Other
Description:
Included picture of vin..hard to read and might have typed it in wrong
It's a 68 f250 with original vin match 390. 67k miles.2wd single cab. I've completely redone almost everything on the block besides internals. Such as pistons and valves. Had under dash ac but not hooked up. Rust hole on floor by gas pedal. A few other random dime size holes around the truck...hood is pretty crusty by hood latch. Fender walls by engine has surface rust due to hood being off. But still solid. Inside fuel tank is removed. Wss going to replace it but haven't yet. Other tank is plastic under the bed. Tires are shot. Need brakes. Has front disc rear drum. Automatic transmission. New parts are as followsCarb-rebuilt also have original one Timing chain and gaskets Water pump Rad hoses and thermostatStarter solenoid Oil pump and dropped oil pan and cleaned inside Alternator Distributor with cap n rotor Master cylinder and brake booster. Transmission pan was dropped and cleaned out as well. New gaskets. Plugs n wiresI also have new ss Transmission cooler lines that run to radiator.
