OBS F150 parts (93-96) INDIANA
For SaleMiscellaneous
Description:
All parts are located in Marion, Indiana and are for LOCAL PICKUP ONLY. Prices are FIRM.
BARE CAB from a 94. It is the extended cab. By "bare cab" I mean a totally stripped shell. Does need cab corners, but the floor and rockers are decent. Includes title. $150
TRUCK BED IS SOLD!!!
PASSENGER DOOR- complete with PW, PDL. Has a small dent below the door handle that would be easy to fix, but no rust. $50
RADIATOR- from a 5.8 truck. No leaks, no broken tabs $50
FAN SHROUD from above radiator $20
AC CONDENSER removed from working system $30
INNER AND OUTER HVAC BOXES- includes heater core and evaporator. Not all cracked up $30
REAR AXLE WITH SWAY BAR- Axle code H9 $50
Also have the following items off of the same truck- everything is $20 EACH, and sorry, I just don't have the time to track down boxes and ship, so please don't ask. Local pickup only because I am extremely busy, sorry.
$20 EACH:
Air filter box and tubes from a 5.8
Left quarter glass (obs extended)
Right quarter glass (obs extended)
Grille- driver quality
Wing window, driver side
Set of hinges for both doors and hood (but not the hood spring assemblies)
Pedal and bracket set: includes gas pedal, auto brake pedal, e-brake pedal, and aluminum bracket
Rear bumper bracket set, including a driver-quality bumper with a mild dent
Booster and master cylinder (has port for cruise switch)
Front sway bar
Pair of rear springs
Crossmember for an E4OD
INCOMPLETE set of BLUE interior plastic, which includes ONLY the following: upper and lower quarter pieces (ext cab) for both sides, back wall, kick panels, A-pillars, and upper windshield and back window trim. DRIVER QUALITY.
