Spring cleaning; have available
hood - good shape, minor rust front edge
8 foot styleside bed - excellent outside, wheelwells, floor (except one small rust spot at front)
tailgate - real OEM original, excellent, no rust, blasted, epoxy primed
shifter tube, excellent OEM 3-spd
rear bumper, fancy factory chrome style, no dents or beds, but chrome is showing its age
set of 15" X 8 alum wheels 10 hole style like Bronco/Eddie Bauer, P225/75R15 tires, 75% tread,
with detachable center caps, red centers, all OEM Ford pieces.
Make offers - need the room...
425 236-7926 anytime
Eric, I have a '66 F-100 clutch pedal/arm but not a brake pedal. Will that help? Are you talking about the whole mounting assy. between the dash and firewall?
I converted to automatic, so I just removed the clutch pedal/arm and left everything else as it was, since it just swings/hinges in the brake pedal pivot tube anyway.
No heater parts either, sorry.
Carson
I'm looking for a passenger side steering knuckle for my 64 F250. Specifically, a dana 44, standard, non HD, not large ball. You don't happen to have. a match for me, do ya?
Spring cleaning; have available: Hood - good shape, minor rust front edge: Same 1961/66 F100/700 & B500/700 (school bus).
1964/66 F100/250 2WD // 1966 F100 4WD 8 foot styleside bed - excellent outside, wheelwells, floor (except one small rust spot at front)
tailgate - real OEM original, excellent, no rust, blasted, epoxy primed. Tailgate has same applications as the bed.
shifter tube, excellent OEM 3-spd: C5TZ-7212-C= 1965/68 F100/250, 1969 F100/250 before serial number D96,001 // 1969 F100/250 2WD from serial number D96,001 & 1970/72 F100/250 without P/S
rear bumper, fancy factory chrome (Contour) style, no dents or beds, but chrome is showing its age: Same: 1964/66 F100/250 2WD // 1966 F100 4WD // 1967/72 F100/250 // 1973/77 F250 4WD (High Boys) // 1973/79 F350's on the 140" wheelbase.
Parts fit far more than just 1966 F100's.
How about $75 plus $15 shipping?
If you don't like it, send back for refund, but it is really in good shape.
Sorry, no stone deflector...
PM with address, contact info.
Thanks, Carson
