1951 F1 with 351W, C6, MII front end
For Sale1951 Ford F1
Price
$22,500• OBO
- Location Sewell, NJ, 08080, USA
- Condition Used
- VIN F1R1LU14402
- Mileage 250
- Engine 8 cyl
- Drive Type 2WD
- Transmission Automatic
- Vehicle Type Truck
- Exterior Color Blue
Description:
Winter pricing! 351W with hot cam, C6 with new valve body, PO did the interior and new tinted glass and gaskets. He also sanded down cracks in the paint which shows the same number of coats of paint on all surfaces except the tail gate. This is a South Carolina truck with it's original sheet metal! Being a SC truck, it does not have a heater or defroster! I have put a Mustang II front end in with power R&P steering, PDB, 1" dropped spindles, new firewall mounted booster/master cylinder, new brakes and many new brake lines, new Saginaw pump, electric fan (puller type), reupholstered seat with springs, chrome tilt column, new sunvisors, Grant steering wheel with Ford horn button, interior courtesy lights, new carpet, Lokar Nostalgia 23" shifter, new dash trim, Omega Kustom gauges, new rims, tires, hub caps, trim rings. Note the door handles do not hang down. Battery is mounted in the bed. The bed wood looks original and is in pretty good shape for it's age. I have two extras grilles, defrost ducts, passenger side mirror and cowl vent assembly that go with the truck.
And yes, I'll trade it. The only thing I will consider is an automatic AMC SC/360 Hornet or a 327 Marlin. I DO NOT WANT A MOTORCYCLE OR ANYTHING WITH A STICK!
