1974 Ford F250
parting out
everything is available other than the rear axle
133 WB
Candyapple Red truck with black vinyl interior
New process 435 4 speed w PTO cover
360 FE 2bbl
Disc brakes
Gauges are nice behind the super faded plastics
Radiator is full of antifreeze and doesnt leak.
Has a nice grille and inserts that will clean up very well and the front bumper isnt bad either other then a few spots on the bottom edge where someone hooked it but could be straightened very easily.
I drove the truck where it sits late last fall so the engine and trans are good. Shifts good.
If your interested in anything just shoot me a message and Ill give you a price and let you know if its good or get you picks when I can.
Need the room but there are too many good parts for me to scrap it. Body panels are junk unless you want to use for patch panels.
Thanks, Matt.
Title
Part Category
Price
Part Description
Sold
1974 Ford F250 Parting Out
Miscellaneous
$1
I will sell anything from the truck other then the rear axle.
There are a lot of good parts left on this truck.
Hello, I accidently threw out the old brake boost with the mount still on it. I am in need of the bracket the connects between the brake boost and the firewall and there may be a level inside of it. if this is available I would love to buy it off you.
Thank you for your time in looking into this for me.
