Wanted Bell Housing and Clutch Fork
Wanted
Drivetrain
  • Expired
  • Price
    Any Price
  • Location Saint Maries, ID, 83861, USA
  • Condition Used
Description:
I am looking for Bell Housing, T18 to a 390 (390, 427, 460). The current Bell Housing is P/N E1TA-7505-AA (I think is a 1973). and the Clutch Fork that goes with it.
Old Dec 3, 2019 | 07:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jtpasto
I am looking for Bell Housing, T18 to a 390 (390, 427, 460 ).
The current 1980/82 351M/400 Bell Housing is ID engineering number E1TA-7505-AA (I think is a 1973 ). and the Clutch Fork that goes with it.
D0TZ-7505-A (replaced C5TZ-7505-B) .. FE Bell Housing / Marked: C5TA-7505-B / Obsolete
1965 F100/250 2WD 352 // 1966 F100 4WD 352 // 1967 F100/350 352 // 1968/76 F100/350 360/390.
There are TWO different F100/350 clutch forks. (1) 1965/69 & 1970 before serial number G30,001 // (2) 1970 from serial number G30,001, 1971/76.
All 1968/82 460's came w/a C6. 1983 was the first year the 460 was available with a M/T (and 4WD). 1983/97 F250/350 460 use a hydraulic clutch.
Old Dec 3, 2019 | 08:02 PM
2dwoods's Avatar
2dwoods
That guy with the post a couple below this one with all those parts must have one
Old Dec 3, 2019 | 08:08 PM
jtpasto's Avatar
jtpasto
No wonder my truck is so screwed up. The truck is a 1981 F350 dually with originally a 5.8 liter engine. It was replaced with a 1984 460 7.5 liter. The transmission is a T18. The bell housing was a E1TA-7505-AA that has been heavily modified. The inside webs were ground down for flywheel clearance and shimmed to get enough clearance for the clutch to work (sort of). I guess I need some serious help on what should be the bell housing, clutch fork, flywheel and clutch pack for a 1984 460, T18 transmission in 1981 F350 dually.
Old Dec 4, 2019 | 03:13 PM
broktruk's Avatar
broktruk
Is yours hydraulic or no?
Old Dec 4, 2019 | 04:10 PM
jtpasto's Avatar
jtpasto
It is a manually actuated clutch, not hydraulic.
Old Jan 25, 2020 | 01:21 PM
427John's Avatar
427John
If your truck currently has the internal balance 460 you will need the D7TA,D9TA,or E1TA bell like the 1 you already have but depending what year 460 you have will determine which flywheel you will have to use,if 78 or earlier you will need a 390 flywheel,if 79 or later external balance 460 you will need the 85 and later 460 external balance flywheel which has more standout from the back of the block and may be the source of the needed clearancing from your current setup.If this is the case you may be better off getting the later aluminum hydraulic bellhousing and swapping a later hydraulic pedal assembly into your truck.
Old Feb 10, 2020 | 01:53 PM
Doug McGibbon's Avatar
Doug McGibbon
Need bell housing for 6.9 International diesel, 1986 F250 4x4 manual 4speed (granny first gear). Mine cracked apart at clutch linkage attachment point.
Old Feb 11, 2020 | 08:04 PM
427John's Avatar
427John
The short answer is none of the factory bells will work with your combination without switching your clutch pedal assembly to hydraulic,then you can use the 85-up aluminum hydraulic bell housing.A Lakewood scattershield may work but I don't know that for sure.
Old Mar 18, 2020 | 07:10 PM
427John's Avatar
427John
JT I v'e got some of these bellhousings in the Spokane area but they're the same as you already have and won't work with the flywheel/clutch you have.I may have an aluminum hydraulic bell but you would have to swap your pedal assembly to hydraulic.
