I'm looking for the radio bracket and bezel for a 73 f100 non ac, That hasn't been hacked up for a single din. I'd like to go back with a shaft style radio.
I'm looking for the radio bracket and bezel for a 73 F100 non A/C that hasn't been hacked up for a single din. I'd like to go back with a shaft style radio.
If you're looking for a specific year/series part, you may have trouble finding it, but if you know what else the parts were used on...
There are two types of dash bezels without factory installed A/C (dealer installed A/C has nothing to do with it), painted and wood grained finish.
These bezels will work on all 1973/79 F100/350 & 1978/79 Bronco.
Pic: Both the 18842 and 18888 brackets are also the same 1973/79 F100/350 & 1978/79 Bronco.
[QUOTE=NumberDummy;18890618]If you're looking for a specific year/series part, you may have trouble finding it, but if you know what else the parts were used on...
Pic: Both the 18842 and 18888 brackets are also the same 1973/79 F100/350 & 1978/79 Bronco. [/QUOT
Thanks for the response! So the bracket I'm looking for is the one that goes on the front of the dash, with the holes for the radio shafts to go through, and also goes over the front of the hvac controls. I don't see it as a separate part on that diagram, but I'm pretty sure it is? I haven't removed the bezel to thoroughly inspect, but if my memory serves me correctly its not part of the dash itself.
