Want to buy #7 mid 80s 460 connecting rod.
WantedEngine - Internals
Description:
Mid 80s 460 connecting rod to replace the one machine shop bent when installing new pistons
I recommend finding a new shop.
Especially when one realizes that all of the rods are the same and do NOT come numbered for position from the factory. The numbers are stamped in by a machine shop when working on the engine internals.
Your machine shop *should* know this and have told you. All that you need to do is find another rod with the correct casting number. Restamp it to match your set if you want but it really makes no difference.
#1 You *never* try to press a pin into a rod. If someone tries to press a pin into place they'll destroy the piston. If someone is trying this it is a sure sign that they have no idea what they are doing. Even then the rod is not going to get bent in such a way as to be ruined.
#2 Ford did NOT mark the rods. If your engines had the rods stamped then they had been rebuilt. Stamping the rods is for engine specific rebuilds done by machine shops to ensure the proper reassembly of the rods and caps.
Do you really think that Ford was going to take the time and effort to make position specific rods, mark them, assemble them to mass produced pistons, and assemble them into a motor?
No. They had a guy grabbing a rod, piston, and pin, and then assembling it. Another guy installing the rings. Then another grabbing whichever assembly came down the mine and stuffing it into the engine.
I started working in Old man Anderson's machine shop in 1973. Learning to build engines. I was co-owner of Aspen Machine for several years. I've worked a couple of decades in machine shops doing every
aspect of engine work and have rebuilt thousands of rods of all makes and styles. With captive pins like the 429/460 and full floating pins like I made for my stroker 474FE.
I've rebuilt dozens of 429/460 engines and I have a 429CJ that I'll be selling soon.
Good engines but I never much cared for the bore size. The flame front can't reach the opposite side of the piston top and therefore they tend to run high on emissions. When you tear down your next 429/460 take a
good look at the carbon build-up pattern and you'll see what I mean.
There are plenty of sites with video and written information on these engines. Check out several of them and find a machine shop with a proper rod oven. Then be careful. I walked into a shop to get some work done.
I looked over and saw the rod-man pulling a red-hot Chevy rod out of the oven. Far too hot!
I left and found another shop.
1979 E250/350 & F150/350 with block casting number D9TE-6015-AB (external balance).
1980/97 E250/350; 1983/96 F250/350; 1988/97 F(Super Duty); 1997 F250 H/D & F350.
460 not available in F150 after 1979, not available in 1980/82 F250/350, reintroduced in 1983. There's no 1998 F250 H/D & F350, as the 1997's were carried over.
to 98 460 connecting rod. yes just one with #7 cylinder stamping preferred.
