Wtb: 1976 f150 4x4 360 oil filter adapter and dipstick
Wanted
Miscellaneous
  • Expired
  • Price
    Any Price
  • Location West Union, OH, 45693, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford 1/2 Ton Pickup 1976
Description:
Looking for an oil filter adapter for a 360 from a 1976 f150 4x4. This is a year and model specific part, 1976 4x4 only. This is the part that bolts to the block that the oil filter spins on to. It has a different angle than other truck FE oil filter adapters. I have swapped an FE into a 1978 f250 and need the clearance. Part number D6TE-6881-AB.
Also looking for a dipstick and dipstick tube for an FE 4x4 oil pan. Would consider buying the oil pan with it.
Old Aug 6, 2019 | 08:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ID engineering number: D6TE-6881-AB
No part numbers marked on parts after 1956, just casting or ID engineering numbers, when applicable.
D6TZ-6881-A .. Oil Filter Adapter / Marked: D6TE-6881-AB / Obsolete
1976 F100/150 4WD
No Ford dealer or obsolete parts vendor has any, none on ebay.
Old Aug 7, 2019 | 07:36 PM
RKDxpress's Avatar
RKDxpress
I have one for 4x4. Points the filter towards the frame ( on its side ). Swapped mine for car style , stands upright. What's different for 76 360?
Old Aug 8, 2019 | 06:58 AM
fordguy76's Avatar
fordguy76
As mentioned above, the 76 f100/f150 4x4 adapter is a model and year specific part. It has a different angle than the others.
