94-03 Ford Super Duty and Diesel F250 F350 Parts (New and Used)
For Sale
Engine - Internals
  • Engine - Internals - 94-03 Ford Super Duty and Diesel F250 F350 Parts (New and Used) - New - 1994 to 2003 Ford F-350 Super Duty - 1994 to 2003 Ford F-250 Super Duty - Bridgton, ME 04009, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $1
    • OBO
  • Location Bridgton, ME, 04009, USA
  • Condition New
  • Compatibility
Make Model Year
Ford F-350 Super Duty 1994 - 2003
Ford F-250 Super Duty 1994 - 2003
Description:
https://maine.craigslist.org/pts/d/b...935060817.html
NEW Filters for Ford 7.3L Diesel:
OEM Ford/Motorcraft Fuel Filter
Baldwin B5134 Coolant Bypass Filter
Baldwin BF1212 Fuel/Water Seperator Filter
Donaldson BHOF DBL7405 Oil Filter (Replaces Stock, much better, bigger filter)
$95+ new, asking $75 for the lot OBO individually.
New Parts:
7.3 Oil Cooler O-Rings (1 set of 4)
7 3 IPR without solenoid. (1)
7.3 Alliant Injector O-Rings (8)
7.3 UVCH Under Valve Cover Harness (2)
99-04 Rear Caliper Bracket (1)
Moog DS1439 Tie Rod End (Long one) BNIB
Make a reasonable offer(s).
Used Parts:
OEM Turbo Up-pipes with new donut gaskets.
2 Sets 4x4 Auto-Hubs, worked/held vacuum, but couldn't spin into manual lock anymore. Bought a 2nd set chasing a vibration, turned out to be front drive shaft.
Oil Pressure Testing Kit ($90 new)
OEM Pontoon Steps for CCSB with hardware.
Bug Deflector (no hardware)
Lower Bumper Valance (removed for plow)
AC Compressor and condenser. System had a leak somewhere, instead of fixing it I removed it.
(8) Used but working Glow Plugs. They worked fine, removed at 120k as a precaution.
OEM Power Steering/Brakes Hydro Pump. Had a hose rub through and just replaced the whole system. Pump worked fine until it was replaced at 120k.
OEM Tensioner.
OEM Silicone Boots for CAC and Spider
Couple sets of front and rear calipers for cores.
Front and Rear Drive Shafts for Rebuild/Parts.
CCSB OEM Exhaust. Cut after down pipe for removal, a coupler and a couple clamps and it's good to go. Been inside since 2011.
Make offers on any/all of it.
Old Jul 29, 2019 | 03:13 PM
ToMang07's Avatar
ToMang07
Bumpity.....
Old Oct 10, 2019 | 02:25 PM
slaton16's Avatar
slaton16
How much for the tie rod end DS1439?
Old Oct 10, 2019 | 11:31 PM
Jregezeino's Avatar
Jregezeino
Are the uvch oem motor craft? Part number?
Thanks, Jon
Old Oct 12, 2019 | 04:26 PM
ToMang07's Avatar
ToMang07
Make me a reasonable offer, it's BNIB.
Thanks, Jon
It's an International UVCH, P/n 1830844c93
Old Oct 12, 2019 | 05:16 PM
slaton16's Avatar
slaton16
Do you have a photo of it or the box just for clarification? Would you accept 60
Old Oct 15, 2019 | 08:28 AM
ToMang07's Avatar
ToMang07
I can snap a pic tonight, but it's the same info.
I'd do $75.
Old Oct 16, 2019 | 08:53 AM
slaton16's Avatar
slaton16
I'd do $75.
Shipped?
I want to ensure the part is there since there isn't any proof of the part
Old Oct 17, 2019 | 09:31 AM
ToMang07's Avatar
ToMang07
Shipped?
Zip code?
Old Oct 17, 2019 | 10:27 AM
slaton16's Avatar
slaton16
Zip code?
My zip code is 30547.
