400 Ford block, crank, rods, and heads for 1978-79 Broncos F-150 F-250
For SaleEngine - Internals
Description:
I have the following for a Ford 400 project that I have discontinued.
1. Block (D7TE-A3B)(Reinforced main webs. 351M/400 truck).has been hot tanked and bored for .030 over pistons (not honed) its sprayed with cosmoline and bagged up. This is the good block that was cast at the Cleveland plant (no crack issues)
2. Heads have been hot tanked, disassembled and one chamber was cc'd at 80cc.
3. Crank (5MAB)is has been cleaned and is standard. Probably needs to be turned, will clean up at 10/10 no problem.
4. Misc small parts: Harmonic balancer, timing cover, flex plate, pulleys, block/starter plate etc.
5. Factory rods with the old pistons still on them
6. I have over $500 just in machine shop fees
Asking $500 to recoup just what I put in to it, your getting the block crank and rods free. I might consider parting these out but want to try everything together first. Buyer will have to pay for any shipping or have someone pick up it up.
See more pictures.I have it listed on craigslist locally.
https://slo.craigslist.org/pts/d/nip...859490222.html
