2000 Ford Excursion Limited 7.3PSD (diesel) lifted 4x4 with lots of mods for sale (Seattle, WA)
For Sale
2000 Ford Excursion
  • 2000 Ford Excursion - 2000 Ford Excursion Limited 7.3PSD (diesel) lifted 4x4 with lots of mods for sale (Seattle, WA) - Used - VIN 1FMSU43FXYEC76734 - 272,236 Miles - 8 cyl - 4WD - Automatic - SUV - Black - Seattle, WA 98178, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
  • Price
    $14,000
    • OBO
  • Location Seattle, WA, 98178, USA
  • Condition Used
  • VIN 1FMSU43FXYEC76734
  • Mileage 272,236
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Black
Description:
Any advice on selling price, marketing, info is welcomed. It's been great being a small part of ford-trucks forums, and I hope to continue with my F-150.
Below is a copy/paste from my Google doc and I'll probably put it up on Craigslist later tonight or tomorrow.
2000 Ford Excursion Limited 7.3PSD (Diesel) lifted 4x4 for sale
I have enjoyed this truck very much for the past several years. I bought it to tow my boat over Snoqualmie Pass 2x/month, and now that I bought a house, I'm selling the boat and I just don't need a ¾ ton diesel anymore, so I downsized to an F-150. I've maintained and repaired this truck as if I would own it forever, but buying a house was too good of an opportunity to pass up.
Specifications & Options
Black over gold/tan; tan leather interior
2000 Ford Excursion Limited, 4WD, 7.3L Powerstroke Diesel
VIN: 1FMSU43FXYEC76734
Build Date: 10/2000
272236mi
Leather seats
Front bucket, mid reclining/sliding bench, rear removable bench seats
Heated seats
Power adjust, heated, manual telescoping tow mirrors
6cd changer in center console
Remote start & locks with 2 remotes & keys
Modifications/upgrades
Custom-built slim fabricated bumper (shorter than factory) with:
  • Tow hooks & shackle mounts
  • Front 2" receiver hitch
  • 20" spot/flood LED bar
  • Amber HID fog lights
  • Block heater receptacle with cover
Complete 2005 front end (core support, grille, headlights & turn signals)
Custom retrofit projector headlights with Morimoto Mini-H1 Stage III kit from TRS
50" curved LED bar above windshield with custom 'visor' to prevent light from glaring in windshield or on hood
Brighter than OEM white/amber switchback LED front turn bulbs (white parking lights, amber turn signal)
White LED DRL strips behind grill
Brighter than OEM LED front marker lights
Brighter than OEM LED rear brake/turn bulbs
Brighter than OEM LED reverse bulbs
Electronic flasher (no 'hyperflash' because of LEDs)
LED interior lights (mid dome, rear dome; front door marker)
LED stip on tailgate for illuminating trailer hitch
Dash storage pocket illumination
Amber LED strips on rocker panel (puddle lights)
LED strip on tailgate to illuminate bumper and trailer hitch
Red rear-facing red LEDs on tailgate for safety
240A ambulance alternator & wiring
6-switch panel mounted below radio with illuminated labels and indicators
Driving lights (all front-facing white lights, can be separated with more switches): auto (with high beams)/off/on
  1. blank
  2. Fog lights: auto (with park lights)/off/on
  3. Reverse lights
  4. Blank
  5. Dome light defeat (not wired yet)
Tekonsha Prodigy brake controller
3 extra 12v power sockets + 2 USB power ports mounted below dash
Edge Insight CS gauge display with EGT sensor
DP Tuner chip and display with following tunes:
  1. Factory
  2. High idle
  3. Low idle
  4. Economy +80HP
  5. Race +120HP
  6. Tow +80HP
  7. Factory
Amsoil dry air filter with prefilter sock
K&N cold air intake tube
Riffraff Diesel Billet Compressor Wheel
Silicone CAC boots throughout (spider/pipe; pipe/CAC; CAC/pipe; pipe/spider; spider/intakes (RiffRaff diesel)
Dieselsite coolant filter with transparent silicone hose for visually checking flow
Mishimoto Thermostat
Dieselsite billet thermostat housing/neck
Dual alternator upper radiator hose (no need to drain coolant to replace serpentine belt)
Fumoto oil drain valve with hose barb (5gal bucket fits perfectly)
Magnefine power steering filter
Magnefine transmission filter
40,000lb transmission cooler
Custom CCV (crankcase vent) oil separator & reservoir
FRx fuel crossover & regulator return (RiffRaff diesel)
HPx high pressure oil crossover hoses (RiffRaff diesel)
Air intake heater plug & code eliminator (RiffRaff diesel)
Silicone charge air cooler boots (6pc) (RiffRaff diesel)
4" lift (front springs, rear blocks) (prior owner, unknown brand)
Polyurethane front Anti-roll bar & end link bushings; upgraded end-link bolts
Polyurethane front and rear bump stops
Polyurethane overload spring bumpers
Rancho RS9000XL adjustable shocks (installed 2018)
Dual damper Skyjacker steering stabilizer (kit with best brackets)
Mile Marker stainless manual hubs (more reliable than OEM)
315-75R16 (35x12) Nankang mud tires on aluminum wheels
Stainless steel brake hoses, including frame to rear axle
liftgate support struts - could change to 4x2 but it's already high with a lift: https://www.ford-trucks.com/forums/1...-supports.html
Roof rails spaced .75" off roof: you can actually tie things down; total height is still <=7'0"
Longer Bosch Icon front windshield wipers (22")
Front row & second row Husky floor liners
3rd row Lloyd Rubbertite floor mat
EBPV (exhaust back pressure valve) eliminated (prior owner)
International bellowed up-pipes
New 4" turbo-back DiamondEye aluminized exhaust (2/2019), all fasteners used anti-sieze
Recent Fixes
Amsoil oil & filter change ()
New interstate batteries (Costco)
'Extreme Duty' 4R100 Transmission (Trans Ends in Auburn) with Billet Triple Clutch Ultra Low Stall Torque Converter
TransEnds addresses these concerns by re-designing the torque converter, re-engineering the valve body accumulation circuitry, modifying the transmission pump and adding a steel support ring to the center support. These upgrades in conjunction with a comprehensive rebuild result in a solid transmission setup to meet the demands of your Ford Truck.
*EXTREME DUTY recommended for trucks with increased engine power, towing or hauling with total GVW 16,000 up and big tire applications. EXTREME Duty series 4R100 and E40D have increased torque capacity with additional clutch plates, recalibrated valve body accumulation for firmer shifts and a TFW Ultra Low Stall Speed Triple Lockup Clutch Billet Torque Converter. The transmission is fitted with a Derale deep oil pan for an additional seven quart oil capacity and increased cooling.
TransEnds remanufactured automatic transmissions meet or exceed the Original Equipment Manufacturer (OEM) specifications. The rebuilding process includes all current OEM updates. All soft parts and the torque converter are replaced. Soft parts include clutches, bands, orings, front and rear seals, lip seals, sealing rings and gaskets. All internal hard parts are inspected and are replaced if not within OEM specifications.
When transmissions need to be tough, there's no such thing as overkill. TransEnds rebuilt transmissions are covered by a Seven Year or 70,000 Mile Parts and Labor Warranty.
Trans & transfer case filled with Amsoil ATF
40,000 lb transmission cooler, magnefine inline filter
Rebuilt limited slip with Yukon Gear clutches (filled with Amsoil 75W140 Severe Gear)
Checked floating rear axle bearings, races and seals - left outer seal replaced, rest good.
Replaced all brake backing plates, brackets, calipers, NAPA poly-coated discs, Hawk severe duty pads, park brake shoes (right-rear caliper piston seized & I went with the 'nuclear option')
Russell stainless steel brake hoses (including frame to rear axle)
Replaced rear axle hard brake line with copper-nickel line (¼" line instead of 3/16" from tee to pass side to reduce likelihood of low pressure and sticking piston that plagues these trucks' rear right caliper)
Brake fluid flush with Lucas DOT3 (highest boiling-point DOT3 I could find; DOT3 has less performance degradation for given water absorbtion than DOT4)
New 240A ambulance alternator (lifetime warranty from Auto Zone), including larger power & ground wires
Custom-built high-pressure power steering hose from Hydro-boost to power steering pump (eliminates Ford's crappy seal on PS pump) (Mobil 1 ATF in steering system)
All new power steering hoses, magnefine inline filter
replaced ICP (Injection Control Pressure) sensor (1yr warranty), includes spare with lifetime warranty & replacement o-rings & electrical connector
replaced driver door lock actuator
Oil/filter/fuel filter, coolant filter change (amsoil oil & filter); oil always synthetic
Older Fixes
Re-soldered headliner trip lie-o-meter computer
Replaced fuel drain o-rings with Viton
Replaced HPOP 'quick' connect o-ring (includes other o-ring & tool to replace)
New radiator (was seeping at tank to core joint)
Replaced idler pulley bearing with new 203FF
New both rear door lock actuators
New front hubs (separate brake rotor) and seals (axles & U-joints good)
Power steering pump
New CPS (cam position sensor) - OEM has bad seal and is known to leak oil
Oil cooler seals replaced
Turbo pedestal seals replaced
Rear oil gallery plug o-rings replaced
Installed bellowed up-pipes to prevent rusting and disconnection from collector due to thermal cycling
Replaced power steering pump
ELC (extended life coolant) complete flush with Zerex ELC (ZXED1); includes extra coolant, but no leaks.
2008+ aluminum differential cover
Inner & outer tie rods & drag link
Upper & lower ball joints
Needs/issues
Typical driver's seat wear on outside seam
A couple of interior plastic trim pieces are cracked
Driver's fender & door dents from sliding into snow long ago (before airing down)
Dent on right rear above tail light (pulling a stump)
Key only physically opens driver door
Extras Included
Extra coolant filters (due next oil change)
HPOP oil line fitting removal tool
Front hub/axle seal seating tool (pipe & ground flange)
Cargo area shelf - behind 3rd row seat, fits four 10-gal Rubbermaid bins underneath
Replacement backup sensors(3) (replaced left outer already and system works)
Expanded aluminum running boards if desires (need mounting brackets)
running boards if desired (need mounting brackets)
Full size 315-75R16 spare tire (unmounted)
Full set of 16x10 aluminum wheels & center caps (were waiting to be powdercoated for next tire change)
Old Mar 30, 2019 | 08:56 PM
thegorilla's Avatar
thegorilla
price updated
No comments/suggestions and no sale, so I reduced the asking price to $14,000
Old Apr 2, 2019 | 11:25 PM
Uriah Morris's Avatar
Uriah Morris
Nice Ride!! Looks like you have encountered or anticipated most all the issues one might face prior to the zombie apocalypse
PM me if you get to the point where you would take 10K, its all my meager budget will bear
Old Apr 3, 2019 | 01:28 AM
thegorilla's Avatar
thegorilla
Haha, I've tried to anticipate more than encounter, but it goes both ways.
I will let you know if I do.
Old Apr 3, 2019 | 12:37 PM
AntonioCm1983's Avatar
AntonioCm1983
Amazing rig
That's a pretty good price for all the work and upgrades
Old Apr 3, 2019 | 01:43 PM
thegorilla's Avatar
thegorilla
Thanks, I thought so and I'll just be patient. I think it's just a small but particular market.
Old Apr 3, 2019 | 04:10 PM
AntonioCm1983
Very nice rig
I would buy the truck but I'm to far away Arizona a good long drive
Old Apr 3, 2019 | 08:10 PM
thegorilla's Avatar
thegorilla
Well, not to pressure you, but the guy who just bought my M5 came from LA, and I bought that M5 from Tempe.
I've also bought cars from NJ and OR. It's all about the total cost & value.
For this or any other vehicle, especially a "niche" market, geography is not such a big barrier, and it really increases your pool of potential vehicles. Just factor in shipping and/or road trip.
Old May 2, 2019 | 10:16 AM
thegorilla's Avatar
thegorilla
Sold to a local buyer. I'll miss the "Excavation" and wish him well with it.
