Ford F-350XL Supercab V-10 ZF-6 Manual 4.3 Rear Axle , One Owner
For Sale2003 Ford F-350 Super Duty
Price
$9,900
- Location Ocala, FL, 34482, USA
- Condition Used
- VIN 1FTSX30S63EC89268
- Mileage 91,000
- Engine 10 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Truck
- Exterior Color White
Description:
Ford F- 350 XL Supercab , V-10, ZF-6 Manual Trans. 2WD, SRW .Long box 4.3 rear axle with limited slip differential. 91K miles,One-owner , exceptional new truck condition ,no rust not even a scratch . Camper package,Reese 16K 5th wheel hitch,class V hitch, telescopic tow mirrors,tonneau cover.Well maintained with maintenance records. Rated to tow 13,800# 5th wheel,12,500 trailer. $9,900.00
Primary Features
Build Date: 27.03.2003Vehicle Line: F250/350/450/550 Super Duty
Body Style: Super Single Cab
Version: 350 Series
Engine: 6.8L SOHC EFI NA V10 Gas
Transmission: 6 Speed Manual
Drive: LHD RWD
Axle Ratio: 4.30
Emission: California Emission Requirements
Air Conditioning: Manual Air Conditioning
Territory: (+)"USA"
Paint: Oxford White
Minor Features
- Medium Flint
- G-Grain
- Blocker Beam-Underbody Front End
- With Tailgate Lock
- With 8' Styleside Box-Steel
- With Load Box Edge Protectors
- 158"/4013MM Wheelbase
- (-)"XL"
- (-) Version Packages
- Less Special Purpose Vehicle
- Less Fleet Related Items
- Kentucky Truck Plant Build
- U.S. Sales
- Less Security Lock Group
- With Camper Pack
- Complete Vehicle
- 9700 LB. GVW
- Less Appearance Group
- Less Exterior Appearance Pack
- Less Power Equipment Group
- Less Ambient Temp/Speed Pack
- Job No.2 Program Control
- Kentucky Truck Plant Build Only
- With English Language Label
- Owner Hand Book Pack
- With 2 Ton Mechanical Jack
- With Manual Front Windows
- With Hinged Side Windows
- With Tinted Glass
- With Fixed Rear Window
- Less Overhead Console
- Less Floor Mounted Console
- Fixed Foot Pedals
- Less Front Floor Mats
- Less Rear Floor Mats
- Floor Cover - Vinyl Ins - Complete
- Sunvisor - Single Driver W/Strap
- With Sunvisor Mirror - Passenger
- With Level 1 Door Trim Panel
- Grab Handle Side Door - Plastic
- With Sound Insulation Pack Level 1
- Less Exterior Sun Visor
- With Grey Grille
- Less Exterior Wheel Lip Moulding
- Less Lower Body Moulding
- Less Rear Window Protector
- Less Side Auxiliary Step
- With Dipping Rear View Mirror
- Dual Sail Telesc TT Mirror-Manual
- Less Temp Control Driver Seat
- Less Temp Control Passengers Seat
- With Seat Belt Warning Light
- With 2nd Row Bench Seat - 3 Passngr
- With Driver 2 Way Mnl. Seat Adjust
- With Pass 2 Way Manual Seat Adjust
- Trailer Tow Prep Pack
- With Trailer Towing Attachments
- With Front Towing Hook
- Exterior Door Handle - Black
- Super/Super Single/Super Cab 4 Door
- With Manual Door Locking
- Less Door Entry Remote Control Unit
- Less Sun Roof
- Less Body Tu-Tone Paint
- Less Bodyside Accent Stripe
- Front Bumper Steel - Painted - Std
- Rear Bumper - Steel Step - Painted
- With Front Licence Plate Bracket
- With Inertia Front Seat Belt
- With Driver Air Bag
- With Passenger Air Bag
- Adjustable'D'Ring-Drivers Seat Belt
- With Passenger Air Bag Deactivation
- With Frame Mounted Tyre Carrier
- With Steel Spare Wheel
- Std Duty Dual Front Shock Absober
- With Standard Rear Shock Absorbers
- With Single Rear Wheels
- 7 X 16" Steel Road Wheel
- LT265/75R-16E A-S BSW Tyre
- With Conventional Spare Tyre
- Less Wheel Covers
- With Black Wheel Hub Cover
- Less Immersion Heater
- Less Attitude/Ride Height Pack
- With Standard Duty Front Suspension
- With Front Stabilizer Bar
- With Heavy Duty Rear Springs
- With Rear Stablizer Bar
- 4.30
- Rear Axle Limited Slip Differential
- Ford Axle Type
- Rear Axle/Wheel Lube-Mineral Based
- With Twin I Beam Front Axle
- 6.8L SOHC EFI NA V10 Gas
- With Catalyst
- Less Exhaust Pipe Extension
- With 4 Wheel Disc-Brake
- 4 Wheel Anti-Lock Braking System
- Trans Power Take Off Provision
- Less Transfer Case
- Less Skid Plates
- Less Clean Fuel Fleet Vehicle
- With Mid-Ship Fuel Tank
- For Unleaded Fuel
- Less Diesel Fuel Content
- Less Steering Damper
- With Fixed Steering Column
- Basic Type Steering Wheel
- Less Speed Control
- Less Auxiliary Heater
- With MPH/KMH Speedometer
- Less Reverse Proximity Sensor
- Less Engine Immobiliser
- Heavy Duty Battery
- Heavy Duty Alternator
- Electronic AM/FM/Stereo With Clock
- With NAAO Radio Frequency
- Less 4X4 Version Pack
- With Sealed Beam Headlamps
- Less Daytime Running Lamps
- Less Front Fog Lamps
- Less Roof Marker/Clearance Light
- Less Engine Compartment Light
- With Dual Beam Dome Map Light
- Less Glove Box Illumination
- With Load Compartment Lamp
- Tail lamps - Level 1
- With High Mounted Stop Lamp
- With Conventional Headlamp Control
- Oxford White
- 350 Series
- F81A 5310 SA Left Front Coil Spring
- F81A 5310 SA Right Front Coil
- Less B&A Control Codes Issue 030388
- Less LPO 50S Emiss Calib Label
- 6 Speed Manual
- F250/350/450/550 Super Duty
- (-)"N"
- (-)"CDN"
- (-)"AUS"
- (-)"GU"
- (-)"BRN"
- (-)"BZ"
- (-)"ATG"
- (-)"CHN"
- (-)"BO"
- Mrkt Comb-SD Airbag Drvr/Pass
