LOMAX Tri-Fold Tonneau Cover 2017+ Ford F-250 Shortbed
For SaleAccessories
Description:
From AgriCover website:
The LOMAX(TM) Hard Tri-Fold Cover maximizes your truck with a low profile design and maximum protection. This lightweight hard tonneau cover is designed for strength, security and style, while being easy to use and offering a simple one person installation and removal. This hard folding cover uses strong aluminum panels with durable, watertight, water resistant hinges. The panels are made from aluminum alloy used to make commercial trailers and coated with a textured matte black finish to perfectly complement your truck and OEM bed caps. Extruded aluminum channels under the panels keep the hard truck bed cover rigid while reducing weight. Flexible rubber seals, water resistant hinges and limited metal-on-metal contact all work together to reduce noise and vibration for a quiet ride.
Starting MSRP $1,039.
