Offenhauser 6019DP intake, ford 300/240/4.9
For SaleEngine - Intake/Fuel
Description:
I have an Offenhauser DP intake for a Ford 300/240/4.9. It is in perfect shape. All the mounting tabs are solid. It comes with a coolant exchange manifold that bolts to the bottom and allows you to run engine coolant through the manifold for better driveability. The manifold sells on Summit for $350 new. If you buy the coolant manifold, it'll cost you between $60--$100. I'll let them both go for $240, plus $20 postage. US lower 48 only.
