WTB 1973-1977 F150 Sliding Rear Track and Latch
Wanted
Interior/Upholstery
  • Expired
  • Price
    Any Price
  • Location Virginia, VA, 22821, USA
  • Condition New or Used
  • Compatibility
Make Model Year
Ford F-150 1973 - 1977
Description:
Looking for the rear window sliding track and latch for a 73-77 f150.
Also looking for a non rusted locking mechanism for the bedside toolbox
Old Mar 7, 2019 | 04:05 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You mean complete outer handle with key cylinder and inside latch for the tool box? Sliding track, you mean the bottom part the glass slides in with the black cats whiskers/felt that is INSIDE the frame?
Old Mar 7, 2019 | 05:38 AM
Bmd2324's Avatar
Bmd2324
i found the locking mechanism for the beside toolbox, but still the latch for the slider. And yes inside the frame.
Old Mar 7, 2019 | 06:47 AM
77&79F250's Avatar
77&79F250
Do you need the metal one or the plastic one? As far as the slider lock latch?
Old Mar 7, 2019 | 07:11 AM
Bmd2324's Avatar
Bmd2324
I need the Plastic slider
Old Mar 7, 2019 | 07:17 AM
77&79F250's Avatar
77&79F250
The plastic one is notorious for breaking. Changing over to a metal one is not that hard. Little screws versus rivets.
Old Mar 7, 2019 | 07:35 AM
Bmd2324's Avatar
Bmd2324
This would be the second plastic one that I have put on. If you have a metal one I’ll take it and give it a shot
Old Mar 7, 2019 | 07:43 AM
77&79F250's Avatar
77&79F250
I will have to get "off the road" and will look in my parts shed. I have so much of the little pieces and parts, hard to stay up with it all at times. You can always make some drop in lock rods. Take some 1/8 metal bar stock cut to the right length and use them to prevent the window from being slid open.
Or reverse that and make a 1" wide X length (what ever the total width of both sliders are) piece of stainless strap and bend each end with a 100* bend angle and clip on/lock the windows. Yes each idea is getto but works in a pinch.
Old Mar 27, 2019 | 02:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The original 1970/91 plastic latch is available from Ford.
EOTZ-1040860-A (replaced D0TZ-1040860-A) .. Sliding Back Window Latch / Available from Ford = MSRP: $7.89
