Looking to buy an FE Block or Motor
Wanted
Engine - Complete
  • Expired
  • Price
    Any Price
  • Location Gilroy, CA, 95020, USA
  • Condition Used
Description:
I have a 390 with a cracked cylinder bore and am looking for a decent FE block to replace it. Ideally, I'd like to find one that will clean up at .030 over (and somewhere in the vicinity of Northern California--though I'm also willing to pay for shipping). A bare block would be fine, but an assembled engine would work as well.
Old Nov 16, 2018 | 11:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1968/76 F100/350: 360/390 use the same engine block, the bore is the same (4.05"), the stroke is different: 360 = 3.50" .. 390 = 3.78."
Old Nov 16, 2018 | 07:11 PM
sawmaned's Avatar
sawmaned
motor
what year truck are you putting this in,?
Old Nov 16, 2018 | 07:18 PM
ford390gashog's Avatar
ford390gashog
There is a few at pick and pull right now.
Old Nov 16, 2018 | 07:49 PM
sseebart's Avatar
sseebart
Got a link? When I took a look at the site, it asked for make, model and year, but nothing came up for Northern California.
Old Nov 16, 2018 | 07:50 PM
sseebart's Avatar
sseebart
FWIW, I don't need this for my truck, but for a 64 Thunderbird. As NumberDummy pointed out, most any FE block will do.
~Steve
Old Nov 16, 2018 | 08:13 PM
NumberDummy
Not in this situation it won't.
1958/64 FE engines were only installed in cars, have a different bolt pattern on the block where the rubber insulators bolt on than 1965/76 FE engines.
This means that if you get a 1965/76 block, your Thunderbird insulators won't bolt on, so you'll have to fab some brackets.
390 introduced in 1961, were installed in 1961/64 Mercury and Thunderbird exclusively, in some 1961/64 full sized Fords, because some had 352's.
Old Nov 17, 2018 | 10:27 AM
sseebart's Avatar
sseebart
Good to know--thanks. I've found a potential block about three hours away via Craigslist and am heading out tomorrow to take a look. According to the seller it's never been bored out and "there are no casting numbers"--whatever that means.
These once-common blocks are becoming scarce, especially in good condition. Fabricating brackets wouldn't be a deal breaker. Do you know, though, if the casting at the mounting pads are different from 64 to 65? I'm wondering if my machine shop can simply drill out new mounting holes at the old location.
~Steve
Old Nov 20, 2018 | 11:59 AM
resonateur's Avatar
resonateur
Steve:
Depending upon how your investigation works out...I have an original 352 from a 66 truck and it has never been apart or rebuilt. It was running when I took it out of the truck and replaced it with a 390. Bakersfield, CA.
Old Nov 20, 2018 | 01:38 PM
sseebart's Avatar
sseebart
Thanks for the offer. I found a block with a Thunderbird dismantler & parts refurbisher on eBay. Mag and sonic tested, bored .030 over. Added bonus--cast date is only weeks away from my original.
As always, I appreciate the help and interest!
~Steve
