1973-1979 truck parts
For Sale
Miscellaneous
  • Price
    $1
    • OBO
  • Location Hopkinton, MA, 01748, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford Any Model 1973 - 1979
Description:
UPDATED LIST 2/10/2021
302/351, 240, 300, 360, 460 engine stands perches
AM FM working Radio
Am working radio
1973-77 grill shell, new and used
1978-1979 grill shell
Rear sliding window
c4 good for core
radiator shrouds 302
radiators
1979 front disc brakes for conversion of older ford trucks.
New master cylinder and brake booster
headliner
Power Steering gear boxes RF D7TC-3550-CA 4 WHEEL DRIVE. D1tr-3550-BA 2wd F150/250 box with pitman arm D2TA-3590-BA
Air cleaner air intake tube assembly D3TF-9A624 AA, D7TE 9A624 DA, D8TE-9C604-BA
power steering pump bracket 240 300
AC brackets D6TA-2882-BA, D3TA-2882-AA, D6TA-2888-AA
saddle tank shield
1978 ford f150 4x4 booster and master cylinder brackets
Full set of long bed and cab and fender and door dent side trim with rubber insert
302 D3OA-9425-AA intake
heater fans and boxes, Ac parts
wire harnesses 1979, 1978, 1974, 1973
Steering columns and wheels,
1973-1979 FORD SHORTBED RAILS
FENDER SHIELD & HINGE SUPPORT, REPAIR 1973-1979 inner fender TRUCK BRONCO. brand new
2 wheel drive 1976 f250 rolling frame
running 360 with a c6
many ford truck ac parts air conditioning. vents, vent hoses, blend door units heater box, dash bezels, dash
controls with vac lines for regular cab, for rear glass cab, for dual tank cab. etc.
LMC truck horn new in box 36-2150 low
T18 bell housing for 300
D1TA-8394 aa manual bell housing 1971-76 FORD 4-SPEED BELL HOUSING 300/302/351W and shift parts. Z bar, equalizers, etc
D1TA-6394-AA. Per the internet, this bellhousing fits the 302 cylinder V8 engines and truck 6 cylinder engines in the early 70s. May fit other models and years.
STARTERS:
D0of 11131 b 302 manual transmission,
D0af-11131 b, 302 manual transmission
390/360 starter
D2af-11131-ca, 289-302 auto
windshield washer reservoirs
two sets of map pockets doors xlt ranger
dash Bezels
Air cleaners
Air horn tanks
302 engine parts-heads and engine parts/ 300 block, head and engine parts, 240 block, cam. pistons
headliners,
Headliner trim super cab and regular cab
door and window parts, windows
360/390 fan radiator shroud
hood locking latch
BELL HOUSING FOR 300, ring gear and clutch
Super Cab rocker trim
narrow and wide dent side trim
Exterior trim, grills, and grill inserts, bed trim, cab trim
Dash,
power steering pumps
ford motor company hub caps/wheel cover
LMC 40-0834 Hex nut 73-79 flareside. new in bag
302 exhaust manifolds:
C4OE 94030, C4OE 9430 A, C5AE 9491 B, D3DE 9431 EA, D5DE 9430, D3DE 9431 EA, D5DE 9430 BD, D1AE 9431 BB, D1OE 9430
Various cables, emergency brake and speedometer cables for ford trucks. 1973, 1974, 1975, 1976, 1977, 1978, All are in working order
carburetor spacers
D3TZ-17752-A Right & D3TZ-17753-A Left .. Front Bumper Brackets 1973/77 F250 4WD & F350.
body replacement panels for fender
AM radio Motorola . Model 5FIRAM8. 15D41133D01
fenders, trim, electrical, ignition module, flareside parts, body parts, frame parts,
Carburetor rebuild kit Holley model 1940 50-420-1 15507a elchlin, NAPA new in box
1978-1979 grill inserts
8' Bed (1) for parts, good cross rails
Engine perches 1965/67 F100/250 2WD 240/ show contact info /72 F100/250 2WD 240/300/ show contact info /76 F100/250 2WD, F350 240/300/ show contact info /78 F100/250 2WD & F350 300. Engine perches 400, 302 perches SBF
intake manifold gasket set new MS 90145 Fel Pro
valve cover set new VS 13049 C Fel Pro
Flareside (stepside) license plate holder and light
Flareside (stepside) steps. three for short bed, two for long bed
Flareside (stepside) tailgate chains
Brand new replacement metal patch panels:
Bed rear post
bed inner wheel well
lower fender panel
Much more stuff.
Old Nov 11, 2018 | 09:47 AM
'77F250C's Avatar
'77F250C
Do you have the bracket for the OEM 1977 Ford radio ?
Old Nov 11, 2018 | 10:47 AM
benbuilder's Avatar
benbuilder
i do. email me at chircolandinc@gmail.com
Old Nov 30, 2018 | 11:30 AM
07F150's Avatar
07F150
I have a 74 super camper special. I am looking for the wire harness that goes from the ignition switch to the engine compartment,,,,,I'm not sure what all it goes to because mine is pretty butchered
Old Dec 3, 2018 | 04:04 AM
benbuilder's Avatar
benbuilder
I have a 73 Supercab harness that is mostly complete. email me at chircolandinc@gmail.com
Old Dec 18, 2018 | 02:18 PM
78broncotn's Avatar
78broncotn
What about a 78 auto steering column? The A/C bracket that holds the idler pulley for a 351M/400?
Old Dec 18, 2018 | 02:21 PM
benbuilder's Avatar
benbuilder
No to both 78 auto steering column? The A/C bracket that holds the idler pulley for a 351M/400
Old Dec 19, 2018 | 08:57 PM
RNBinc's Avatar
RNBinc
Looking for a jack and crank handle, do you have any available?
Old Dec 20, 2018 | 01:07 AM
benbuilder's Avatar
benbuilder
RNBinc. I have both. email me at chircolandinc@gmail.com
Old Dec 26, 2018 | 02:40 PM
Airborne-F250's Avatar
Airborne-F250
DO you have any rear ends?
Old Dec 28, 2018 | 07:02 AM
benbuilder's Avatar
benbuilder
no rear ends at this time sorry
Old Jan 2, 2019 | 01:57 PM
thodges's Avatar
thodges
B pillar?
Originally Posted by benbuilder
UPDATED LIST
parted out many trucks. ford truck parts 1973, 1974, 1975, 1976, 1977, 1978, 1979,
300 power steering pump and bracket and gear box
power brake booster and master 1978
saddle tank shield
T18 with bell housing for 300
STARTERS:
390/360 starter
dash Bezels including radio delete bezel
Air cleaners
Air horn tanks
brake pedals,
new window and door seals
302 engine parts/ 300 block and engine parts
headliners,
Rims, ford
Green interior parts
doors and door parts, windows
Radiators and supports for 302/351
360/390 fan shroud
hood locking latch
Exterior trim, grills, and grill inserts, bumpers, bed trim, cab trim
hubcaps,
Dash, dash pad cover
1979 FORD TRUCK SHOP MANUAL WIRE DIAGRAMS
D8TZ1015C White Spoke Styled Steel Wheel 15" x 6" / Marked: LJ. Sandblasted and in primer. 4 wheels with original matching Caps. (wagon wheel)
302 and 351 intakes
Steering columns (auto, and for standard on the floor) and wheels,
Seats
bell housing out of a 73 f100 C4 automatic for small block Ford with pan fill design
ford valve covers 302
ford tailgate flareside stepside
brand new gas tank
radiator shroud for 390/360
302 exhaust manifolds. C4OE 94030, C4OE 9430 A, C5AE 9491 B, D3DE 9431 EA, D5DE 9430, D3DE 9431 EA, D5DE 9430 BD, D1AE 9431 BB, D1OE 9430
351 exhaust manifolds D5AE 9431 AB and matching other side.
carburetor spacers
body replacement panels for fender and cab
fenders, trim, electrical, ignition modules, tailgate, door parts, flareside parts, body parts, frame parts, too much to list
Contour bumper
grill inserts
12127 distributer
hood
Engine perches 1965/67 F100/250 2WD 240/300/352 / 1968/72 F100/250 2WD 240/300/360/390 / 1973/76 F100/250 2WD, F350 240/300/360/390 / 1977/78 F100/250 2WD & F350 300. Engine perches 400
Flareside (stepside) steps. two for short bed, two for long bed
Tabco cab mounts for 1967-1979
Cab corner
Bed rear post
Left and right pillar repair panels
Much more stuff.
1971-1979 Ford Galaxie 500 Ltd Pinto Radio **** D1aa-18a932-aa
Can I see a picture of the left and right pillar repair panels? Are they for the b pillar?
Old Jan 2, 2019 | 02:28 PM
benbuilder's Avatar
benbuilder
email me at chircolandinc@gmail.com and i can send pictures
Old Jan 6, 2019 | 10:55 AM
68F350's Avatar
68F350
Power steering swap
I have 68 f350 with the 360 In it looking to convert to power steering...any chance you would the parts I need to do that?
Old Jan 6, 2019 | 11:07 AM
benbuilder's Avatar
benbuilder
I have a pump and steering box, I would sell as cores as i dont want to guarantee them. email me at chircolandinc@gmail.com
