2011-16 F250/F350 Front Bumper
For SaleExterior Body Parts
Description:
It will also fit on 1999-07 trucks with a small modification which I will explain when you come and check out the bumper. Do not get discouraged as even someone with the smallest tool collection can do this. It sits perfectly under the headlights. This will also allow you to upgrade to the 05-07 style grill without cutting the grill as you would need if you kept your stock bumper in place (grill replacement is not necessary to run this bumper..)
The bumper comes complete with all chrome, upper pads, lower valence, foglights, harness and brackets to install.
Asking 525. Local pickup only. Shipping would be expensive on this
Just the OEM chrome piece from ford is $655 not including every other piece
