2015 Ford Expedition SYNC MFT Display Screen/APIM WITH FACTORY NAV
For SaleMiscellaneous
Description:
FOR THOSE OF YOU WONDERING if this is the same vehicle from the Weather Tech product suite for 2015 Expedition...Answer...YES!
2015 Ford expedition SYNC/MFT (SYNC2) Display screen APIM
TO CLARIFY: This IS NOT THE SYNC 3 UPGRADE screen but the SYNC MFT Screen that was a left over from when I did the SYNC3 upgrade. This is being sold due to vehicle trade in and I forgot to get the SYNC 3 screen removed. This item should be plug and play, this could replace a cracked screen, broken LCD, putting back to stock for trade in etc....
This is the MFT screen for models WITH FACTORY NAVIGATION and Sirius Travel Link. 8" touch screen.
The Photo below is the same type screen installed on a F150 but Expedition installed look is similar. The second photo is a generic SYNC/MFT screen most fleets and sub fleets with the SYNC/MFT use the same screen, programming and function may vary among vehicles but screen is pretty much standard across all Ford Lineup.
As a response to overwhelming complaints and frustration for the slow and often incomplete response from the SYNC MFT (SYNC 2) programming, this system still uses the 8 inch screen and some of the controls went back to physical buttons as back up for the touch screen.
I will only speak for use on 2015 Ford Expedition, this screen may fit other models but I won't take the liability of saying yes or no.
Prefer local (DFW Metroplex area) but will consider shipping. I prefer local pick up to reduce risk of possible damage during transit because as we all know FRAGILE, HEAT SENSITIVE and PERISHABLE labels on shipping boxes doesn't mean what it used to.
PM me if interested $150
