WTB - Clutch and Brake Pedal Assy For 1959 Ford F100 Pickup
WantedDrivetrain
Description:
Looking for the clutch pedal and master cylinder assembly to put a standard transmission in a 1959 Ford F100 pickup. This truck was originally an automatic transmission so I need the necessary pedals and hydraulic clutch master cylinder to change it over. I suspect that the 1957 thru 1960 pickups all use a similar pedal assembly so I'm not limited to just a 1959 model. I'm in Lorena, Texas. If you can fix me up, then feel free to email me as I don't check into the site very often. My contact information is at www.eatonbalancing.com . Thanks in advance, Ted.
I've found a pedal assembly so this ad can be disregarded. Thanks to all that responded. Thanks, Ted.
