1996 Ford F250 Supercab XLT 7.3 Powerstroke Diesel
For Sale
1996 Ford F-250
  • 1996 Ford F-250 - 1996 Ford F250 Supercab XLT 7.3 Powerstroke Diesel - Used - VIN 1FTHX25F1TEA34592 - 323,000 Miles - 8 cyl - 2WD - Manual - Truck - White - Plano, TX 75075, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
  • Price
    $10,000
    • OBO
  • Location Plano, TX, 75075, USA
  • Condition Used
  • VIN 1FTHX25F1TEA34592
  • Mileage 323,000
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Truck
  • Exterior Color White
Description:
1996 F250 Supercab XLT, 7.3L Powerstroke Diesel, 5spd Manual Transmission, 2WD
Features: K&N Performance Filter, Trailer Brake Controller, Toolbox, Custom backseat with headrests, DVD video with HD radio, 325k miles. Valid, current registration tag through September 2018. Will provide recent and historical Blackstone oil analysis reports that show motor is in great shape. Will also provide current Carfax report. This Texas truck has been my daily driver since 2001; it is very well taken care of and gets 19 MPG in mixed highway and city driving. If you need a reliable older diesel truck to pull your equipment or travel trailer, this is a good one. Recent work includes:
- Oil, Lube, Filter every 4k miles with Rotella 15w40 and Motorcraft filter
- Fuel filter replaced 300k miles (Wix filter)
- Coolant replaced every 2-3 years, recharged with FW16 DCA (diesel coolant additive)
- Glow Plugs and Glow Plug relay replaced 12/10/17 (Motorcraft glow plugs)
- Duralast Gold starter replaced 10/8/17
- Vacuum pump replaced 6/17/16
- New Duralast Gold Batteries 4/30/16
- Power steering fluid replaced 2/15/15
- New Michelin LTX MS2 Tires 1/15/15, still in great shape
- New Diesel Fuel Pump 1/15/15
- New Clutch throwout bearing and pilot bearings 1/15/15. Has single mass performance flywheel and clutch
- Complete new frontend on 12/15/15: upper/lower ball joints, radius arm bushings, rear stabilizer link ends, front stabilizer link ends, tie rod ends, alignment, and changed rear differential oil (289k miles)
- Both fuel tank sender units replaced 3/6/15, plus fuel selector valve and dash switch
- Both front wheel bearings replaced 10/24/14
- New AC: compressor, drier, orifice tube, evaporator coil 10/2/13
- New water pump: 9/15/13
- Oil cooler orings replaced and fuel filter cannister leak fixed 2/1/13
- Clutch conversion from dual mass flywheel to single mass using Napa kit 2/1/12
- Manual transmission serviced with royal purple synthetic 7/1/11 (222k miles).
- Brake fluid replaced and bled 7/1/11, 222k miles, new power brake booster and vacuum lines
- New Master and slave clutch cylinders 5/4/11
- New headlight lenses 5/29/11
- New Diesel Wiring harness 11/1/10
- New alternator 7/16/10
Old May 26, 2018 | 06:55 PM
shorton's Avatar
shorton
Sold to local Texas gentleman for $7500
