Sponsored by: Auxito
Speaker Wiring
Old Oct 10, 2010 | 12:01 AM
racerx6466's Avatar
racerx6466
Speaker Wiring
Putting speakers in my 2001 supercrew. Test light broke and need to know which is the positive and negative on the pass front door. I have two black wires, one with a white stripe and one with a orange stripe
Old Oct 10, 2010 | 06:50 AM
highteckredneck's Avatar
highteckredneck
i do believe the one with the white stripe is positive but ill look in my manual when i get home.
Old Oct 10, 2010 | 07:00 AM
n5926g's Avatar
n5926g
Unless there is something "special" about the speakers,it shouldnt matter.
Some speaker systems use one side directly to door frame ground,and others rout the speaker "return"(ground) back into the radio.
Old Oct 11, 2010 | 03:22 PM
Lime1GT's Avatar
Lime1GT
My wiring diagram shows Wht/LT GRN (+) ; Dk GRN/ORG (-); right front pass speaker.
Old Oct 11, 2010 | 06:01 PM
KhanTyranitar's Avatar
KhanTyranitar
It doesn't matter which is which. The only time polarity matters is when you are trying for higher power outputs, in which case, the speakers might cancel each other out. For a typical setup its not going to matter.
