I bought wheels and tires off of a 02 Ford 250 for my 78 F250. They don't fit. From what I've learned they have changed wheel lug layout a couple times through the years.
you are saying wheels off your buddies F-250/350 which is an 8 lug so I am assuming you have an 8 lug as well (I'd guess you're smart enough to not think the 8 lug wheels would bolt on a 5 lug truck ). If so the wheels will fit.
The Super Duty trucks have a metric bolt pattern and will not interchange with the Standard bolt pattern older trucks. You said the wheels were off of an '02 right? and you want them on a dent side, right? no fit.
I guess if you had a big enough hammer they would fit, but they might wobble uncomfortably........
Hard to see in this pic, but these are the aluminum wheels off a 92-97 F-250/350. They have 315/75r16 tires (35") and look dang good on our trucks if I do say so myself!
1997 and older have the same 8 bolt pattern, when the 99 250/350's came along they went to metric and won't fit anything older. Same idea for the 150, 96 and older will fit the older 150's , in 97 the F150's went metric so they won't fit anymore.
And just to confuse you all - or to rather show how idiotic/confusing Ford is - the wheels on my crew pictured above came off a 2009 E-350 van. Apparently the vans (maybe just 8 lug - maybe not) have still yet to change to metric like the trucks did in 97 (F-150) and 99 (F-250/350).
