45K service - Anything else I should do while I'm in there?
Old Aug 21, 2010 | 11:41 AM
smlford's Avatar
smlford
2007- 2.3L auto.
While I'm going to do the service per the manual is there anything else like plugs, diff fluid etc I should consider?
Thanks.
Old Aug 21, 2010 | 07:56 PM
pawpaw's Avatar
pawpaw
Was the auto tranny fluid changed at 30K???? if not I'd consider dropping the pan to change the filter & doing the full fluid pump out listed in the Tech info thread.
Check the upper & lower ball joints rubber dust boots, mine were showing early signs of dryrot at 45K. If you find yours cracked, rub on some RTV to seal them up.
If the inner & outer wheel bearings haven't been pulled, cleaned, relubed & new grease intalled I'd do that.
If you aren't of a mind to do it, at least check the wheel bearing play & adjust as needed.
How about coolant, brake & power steering fluids, have they been changed since new???? I do mine about every 30K
You might pull an easy to get at spark plug or two & check their gap.
I found mine .008 over max spec gap after only 36K & this was after pulling them when new & setting them to the Min side of spec. Yup the new plugs from the factory were all over the place for gap!!!
Use a wire type gap gauge & don't set te gap so tight that you damage the plugs platinum pads. Ease up on the gap setting.
I finally replaced the OEM plugs this past spring with 70K on them & they were worn bad. No way would these OEM Factory plugs have gone the 100K miles they were supposed to be good for!!!!
Drop & air up the spare tire & maybe lube the drop cable & lock cylinder if you have a spare tire lock.
Some thoughts for consideration.
Old Aug 22, 2010 | 01:09 PM
smlford's Avatar
smlford
Thanks PawPaw, I'll ad them to my list.
firedaniel
Sep 30, 2014 09:06 AM
kawcrasher
Feb 23, 2013 10:09 AM
Carny
Oct 18, 2010 10:54 AM
ngng
Dec 25, 2008 08:04 AM
61UniB100
Nov 4, 2006 01:41 PM
