Carbed B2200 running rich
I reused the old carburetor. Since the swap, the engine has run rich and idles high all the time. It is getting only half the mileage it used to get. The choke plate on the carb is opening fully when the engine is warm. It seems like the computer is opening some auxilliary fuel system all the time.
In searching the internet I have found advice on how to retrieve codes from the check engine light, but this vehicle does not have one (Canada only delete, it seems). So I can't get codes that way.
I bought the genuine Mazda shop manual which says to use (of course) the genuine Mazda scan tool which seems to be unavailable on ebay etc. The generic scan tools cover "most imports", meaning not Mazda!
Anyhow, hopefully some clever B2200 enthusiasts can give me a few tips.
Someone here may have experience with your model, but on a dedicated Mazda truck forum, you will probably find more people familiar with your setup.
I'm thinking maybe if it has a real carb as you posted, the ethanol in E-10 has messed with it's seals or the float has a hole in it, or some other way it got messed with in the engine swap & isn't properly controlling the float bowl fuel level.
On a carb, the float drop & rise setting must be properly adjusted to prevent too low a float bowl fuel level & lean mixture, or an over full bowl, or one in which the float rise setting is too high, or the float seal is damaged, such that it doesn't fully shut fuel flow into the bowl off, thus it'll over fill & spill out the bowl vent/s into the venturi & cause a rich mixture.
Or maybe dirt, or sediment in the bottom of the float bowl got stirred up from handling & has cloged something up in the carb, or fuel injector if it has a throttle body/injector set up & is causing the injector pintail to leak.
SO, with the Mazda shop manual, you should be able to dive in there & check out, adjust & clean things up, no matter what system you have.
Edit: Put a fuel pressure check on the list.
The computer & engine would need to be matched too.
The comment about the computer and engine needing to be matched seems like a possible lead, as I don't know what exactly the replacement engine year is. However, since I used the original carb I would think that the computer doesn't really know what the long block is.
I did check the oxygen sensor and engine temperature sensors which gave proper readings when tested with a multimeter. Since I had two of everything I tried swapping the sensors with no improvement.
I'm thinking that I just need some way to probe the primitive brain of the truck to get a code but can't figure a way to do so.
Is the fuel pressure in spec & the carb float bowl fuel level still in the middle of the sight glass????
How is the MAP. or MAF sensor output to the computer???
Is the replacement engine the same size/displacement as the old engine????
I am using the intake that stayed with the replacement engine. I do not know for absolute sure if it is a 2200, how can I tell if it is a 2000? And could this really cause a drop in mileage by half?
I don't know if this engine has MAF or MAP sensors. I tried both the original and fuel pump that came with the replacement engine which made no difference. The return line seems clear when I blow through it.
I'll check for vacuum leaks carefully. I thought this would, if anything, make it run lean, but on second thought I can see that this might confuse the "computer" and make it overcompensate to too rich.
As for being equipped with a "real carb", well that's debatable as it's a vacuum/electronic controlled monstrosity. However, the thread title is "Carbed B2200 running rich".
On the engine size difference, I was thinking maybe if the computer program is set up for one displacement engine & it's used with another, the computer might get confused about a number of things having to do with fuel trim, ect,
This might be made worse if it has a MAP sensor, rather than a MAF sensor, that drectly measures engine intake air flow volume.
Did you get the O2 sensor hooked up & are you certain it's working???? Just a whiff of coolant in the exhaust, is enough to take one out.
The info I have with my Actron CP-9150 scan tool kit, says that Mazda between 88-95 used 6 pin, or 17 pin MECS (Mazda Electronic Control System) diagnostic connectors.
SO, it seems that at least Actron makes a scantool & MECS connector adapters, that would let you hook up a scantool like the Actron CP-9145 & scan for codes, as well as read live sensor PID's to the computer & computer outputs to it's actuators.
SO, if you have, or know someone with the Actron CP-9150 kit that has the CP-9145 scantool & the MECS adapter connector cable in it, or if you know someone that has a CP-9145 scantool, you could order the 6, or 17 pin MECS adapter cable for the CP-9145 scantool from Actron & have a combo that would pull your codes & monitor live computer feeds & that sure would make your trouble shoot much easier.
The Actron 6 pin MECS connector adapter is P/N CP-9131. The 17 pin MECS connector adapter is P/N CP-9128
More possibilities for consideration.
I don't know of any carb systems that used a MAF nor a MAP, but I don't know them all. Are you positive that you put all the carb spacers and stuff back on the new engine? Is it possible the linkage might be 'flipped' in part, where a link has passed its normal range of motion and gone on to working in the opposite direction? Or could the linkage be interfering with other engine parts? A carb will only give high idle if the throttle plate is held open. Some engines had a full-close position on the throttle when the key was off, and an electric solenoid to prop the throttle open with the key on, after you pressed the gas pedal. Not enough solenoid to open the throttle, but enough strength to keep it open until the key was turned off. It prevented run-on when the ignition was turned off.
I have had bad throttle plate bushings that bled extra air, and you could not get the idle down because it would not run unless you had the idle adjustments way out because of all the extra air. Have you checked your throttle plate bushings for slop?
All the above says either a linkage or throttle plate problem for the high idle. The only electronic controls for carbs that I know of were to move metering rods in or out of a jet to vary the amount of fuel flowed. If yours has one of those, it could affect the fuel mileage significantly.
Last thought is the transmission linkage. If you have an automatic, the kickdown rod may be interfering with full throttle plate closure.
tom
When reading the shop manual I did find that there was some electrically controlled metering device in the carburetor that added extra fuel when decelerating with the throttle closed, I thought maybe the computer is confused and holding that thing open or a similar situation.
It is such a pain in the neck to work on the carb because so many vacuum hoses have to be removed just to get to see the carb, and then of course it will be running wrong because the hoses are off.
My sister had a Capri with a 2.3 and California emission controls back when. It had a modified Weber 2 bbl, like on the Mustang II and Pinto of the mid 70's, that had a metering rod that was moved by a solenoid. I *think* it had a throttle plate solenoid that kept the throttle open a bit on deceleration. When you took your foot off the throttle, the car did NOT slow down for a few seconds {define "few"}, and there was little to no compression braking for some period of time. That tactic cut emissions. Was not as much fun to drive, either.
If any of the temp sensors or vacuum delay valves or temperature operated vacuum valves were carried over from the new engine, rather than the old, you might want to consider testing them for proper operation. In other words, you may have imported your problem rather than created it.
tom
