Trying to remove center bolt from leaf spring
Old Jul 26, 2010 | 12:49 PM
BlackNGoldRules's Avatar
BlackNGoldRules
OK, I finally came across a leaf spring from a junkyard to replace the broken spring on my truck. The problem is that it had 4 leaves on it and the ones on my truck have three. I figured that since I've been having such bad luck at trying to come up with a spring I'd just take this one and try to remove one of the leaves. Well, I'm having an issue trying to remove the center bolt. With the bolt head being rounded, all I can do is spin the bolt when trying to remove the nut. I tried putting a pair of vice grips over the rounded bolt head while trying to loosen the nut but it just spins. Anyway, the only idea I could think of is trying to stick a nut over the rounded head and maybe using some JB Weld to "weld it" to the bolt head. That way hopefully I can keep the bolt from moving while turning the nut on the opposite side. My question is, do you think that stuff will be strong enough to pull that off or will I probably end up just breaking the nut off that I tried "welding" to the bolt head? I don't have a welder so this is the best I can do right now. I've read about people just pounding the bolt out but I'm not sure how that is possible with the nut still on. I've also read about trying to cut the bolt but all I have is a hacksaw. Anyway, any suggestions would be appreciated. Thanks.
Old Jul 26, 2010 | 01:31 PM
Beechkid's Avatar
Beechkid
The JB weld won't work. Try either cutting the nut off with a cold chisel or cutting wheel on a hand grinder or use a dremel tool.
Old Jul 26, 2010 | 02:40 PM
powersmoked's Avatar
powersmoked
if you cant get a sawsall just use the hacksaw.........hello that football player cut his car in half with a hacksaw
Old Jul 26, 2010 | 03:57 PM
BlackNGoldRules
Maybe I'll try the hacksaw first and see what I can get accomplished with that. If I run into problems then maybe I'll go buy one of those portable dremel tools. Portable because I may have to do the same thing to the center bolt on the leaf spring in my truck and I don't have a garage or any place near outlets do take it off of the truck spring. I have the leaf spring that I got from the junkyard sitting on my living room floor on top of a bunch of old towels! Yeah, the wife sure loves that. lol I may just take the leaf completely out of this one and stick it in the leaf spring of the truck in case I have trouble getting that spring completely off thanks to those stubborn eye bolts.
robert_l_ross
Sep 1, 2023 03:17 PM
Stewart_H
Oct 24, 2017 11:57 AM
speedr26
Feb 2, 2007 05:59 AM
fred_79f250
Aug 5, 2006 01:30 AM
