exhost valve shutting all the time
Old May 6, 2010 | 06:33 PM
96 D.I.T's Avatar
96 D.I.T
it started a couple months ago, i would be driving down the road, and with my intake i can hear the exhost valve close, then open, then it would close again. noteing the temp was just making it to the normal range, i changed the thermostat. problem solved, so i thought.. now just last week, i fired up the truck and didnt let it worm up too mutch, as i had drove 10-15 mi. about 1hr before, and i had little to no throtle for about 2min. then all of a sudden i could hear the valve open and the turbo spool up and all was good. till the next time i started it, when it is almost worm, and the same thing. i didnt think it was a big deal till i went to pull out in traffic and the truck wouldnt do more than 10 mph. no ETC's lights or other, and once its worm it still closes once and a while, but not enough to cause a problem with driveability. im not shure where to start.
96 f-250 e4od 4x4
Old May 6, 2010 | 06:47 PM
fordpride's Avatar
fordpride
what is the temp were your at? could be a exchaust back pressure sensor. just unpluge it the pluge is under the driver side of the turbo wait til the eng. is cold and unplug it before u start it.
Old May 7, 2010 | 06:39 AM
Neal 97 250's Avatar
Neal 97 250
I would just unplug it. There is a two prong plug just under the turbo. Unplug that wire/ plug and you should be just fine.
Old May 7, 2010 | 11:09 AM
Brown Falcon's Avatar
Brown Falcon
Either unplug it or wire it up to a switch on the dash so you can use it when it's cold.
Unplugging it will make it stay open all the time.
Old May 7, 2010 | 11:24 AM
Neal 97 250
I wired mine to a switch also. It works decent for an exhaust brake as well.
Old May 7, 2010 | 12:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
X3 what they said. good luck.
Old May 7, 2010 | 02:52 PM
96 D.I.T's Avatar
96 D.I.T
im on my way to un plug it, thanks
