300 I6 won't start immediately after shutdown
Old Apr 9, 2010 | 12:57 AM
Traderjoe28's Avatar
Traderjoe28
My son has an '87 300 I6. The engine starts fine, initially, and will run beautifully until you turn it off. However, when you shut it off and try to re-start it either immediately or anytime within about 4 or 5 minutes, it won't fire back up. When you turn the key to the "ON" position, you hear the electric fuel pump run for a couple of seconds to pressurize the fuel rail , and then starter cranks the engine over just like normal, but the engine absolutely will not start back up. It doesn't even make any sound like it's trying to start. But wait about 4 or 5 minutes, hit the starter, and away she goes without any hesitation at all - just an instantaneous snap of the starter and the engine jumps alive.
This happens regardless of weather or not the engine is or is not up to operating temperature, so I don't believe it's vapor lock in the fuel rail. It's a real "puzzler".
Any suggestions as to what the problem is?
TIA for any possible solutions to this frustrating problem.
Old Apr 9, 2010 | 08:25 PM
sixing's Avatar
sixing
Maybe check for spark at the spark plug and fuel pressure at the pressure rail fitting when you have the no start situation. This would narrow problem to electrical or fuel. You should have spark and pressure when cranking.
brentbenish
1983 - 2012 Ranger & B-Series
16
May 27, 2015 05:46 PM
4601ton
Jun 18, 2011 10:53 AM
myankow
27
Aug 28, 2004 09:36 PM
kluelessjo
Bronco II
Aug 30, 2003 06:50 PM
