holley or rochester??
Old Mar 13, 2010 | 10:39 PM
stormdraconis's Avatar
stormdraconis
I got a motorcraft 4180 and one of the accelerator diaphram bolt holes on the primary fuel bowl is striped out tried a helicoil to fix the problem just made hole bigger and didn't work a guy told me to use a two part epoxy thread repair and it seem like it works but once I get it on the 85 351w bronco will it still work. If it doesn't work a friend of mine has a quadra jet that he said I could use if there is a problem if so do I have to get it rebuilt and if yes about how much is a q-jet kit or is there a diffuculty finding them or is there another solution that someone could think of. Besides buying a new carb I really want to get a 600 edlebrock but with the way the car looks right now its like a dope fiend with a with a 5 karat diamond ring if anyone can understand my analogy thank you for any help
Old Mar 14, 2010 | 01:28 PM
LxMan1's Avatar
LxMan1
Well, the Q-jet won't bolt up without an adapter and will have no passing gear hook-up.
The thread repair should hold once installed. Give it a try first.
Old Mar 14, 2010 | 08:45 PM
stormdraconis
It didn't work still got leak at accelerator pump going to try the rochester and if I still got issues ill be riding with a edlebrock and be that dope fiend with the 5 karat ring unless someone got another solution for me
