2006 ranger 4.0sohc ,auto (shifting issues)
Old Mar 2, 2010 | 09:41 AM
dd3's Avatar
dd3
2006 ranger 4.0 automatic
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message -->ok i'm new here and i've read some of the posts regarding shifting issues,well here's my problem. A few weeks now my truck shifts abnormal and i just thought it was the cold weather. it shifts fine untill it reaches the higher gears then although it still accelerates the rpms are high. Once i let off the gas it shifts,once warm it seems to do better. i had a mechanic check for error codes but none showed up. I'm thinking a solenoid is sticking but not a car mechanic. please help ! I've read abouth the valve body gasket but if this were the case would'nt it be leaking.should i replace the solenoids or what
Old Mar 2, 2010 | 07:54 PM
Rockledge's Avatar
Rockledge
Keep in mind that most Ford tranny codes cannot be pulled with a standard OBD-II code reader; it takes a more sophisticated, Ford-specific reader.
How many miles on the truck?
Old Mar 2, 2010 | 10:44 PM
dd3's Avatar
dd3
2006 ranger extended cab xlt 4x4 with almost 57000 miles on it. I carried it to a reputable mechanic and np codes or errors showed up on motor or transmission. any help would be greatly appreciated
Old Mar 3, 2010 | 09:10 AM
pawpaw's Avatar
pawpaw
With it acting better as it warms up & no tranny codes showing, it could be a little gum, varnish, or sludge hanging something up.
Has it ever had a tranny filter change & full fluid pump out????
If not, you might consider trying 1/2-1 can of Seafoam Trans Tune in it (don't over fill), then driving it & see if you notice any improvement. If so, it's likely a deposit problem hanging something up, so drive it until the problem stops, then do a pan drop, filter change & full fluid pump out like this.
https://www.ford-trucks.com/forums/6...-pump-out.html
Be sure to use a quality made Mercon-V fluid, that says it meets or exceeds Fords Mercon-V specification, for the fluid change & use a Motorcraft/Filtran tranny filter.
If it doesn't get better with the Seafoam, deposits aren't likely the problem, so you might have something like a gasket, seal, solenoid, pump, ect, problem, that'll need a Dealer, or good tranny shop to diagnose.
Driving with it slipping will damage the clutch packs, so don't put off having it checked out & serviced if the Seafoam doesn't do any good.
Some thoughts for consideration, let us know how it goes.
