fuel fiter
Old Feb 27, 2010 | 08:01 PM
lil'bubba's Avatar
lil'bubba
fuel fiter
where i s it at and is hard to replace check out my ride need a littel love in tampa this thing is just like me i eas born with 1 eye thank you for all your help lil truck with big heart
Old Feb 28, 2010 | 07:13 AM
bratman2's Avatar
bratman2
Bubba, should find it under the driver's side inside the front bed frame rail. They make a little tool that cost about $7 that really helps out alot. should be able to find it at any NAPA, Advance or Autozone. I got mine at Advance. Took me a total of 2-3 minutes to replace mine.
Old Feb 28, 2010 | 07:51 AM
powersmoked's Avatar
powersmoked
on your model you probably have a little push button on the line. it makes it much easier to change , no little tool needed
Old Feb 28, 2010 | 08:13 AM
msgtord's Avatar
msgtord
Same for the 2006?
Old Feb 28, 2010 | 08:17 AM
03 Maz B23's Avatar
03 Maz B23
Be sure to relieve fuel line pressure before removing fuel filter. Pull fuel pump relay( in large relay box under hood) and run engine till it stalls. To remove clips on fuel line look for flat part of plastic horseshoe clips and use a small flat screwdriver to press in clip while moving line toward filter and then pull line off. Have a rag handy cause some fuel still will come out.
Old Feb 28, 2010 | 10:10 AM
lil'bubba's Avatar
lil'bubba
thanks guys talk at you latter check out my ride
Old Feb 28, 2010 | 11:02 AM
jammonster's Avatar
jammonster
hey 03 Maz B23, jammonster here. thanks for the info on the fuel filter. You know your sh%$.........
